02-26-2007, 07:54 PM | #1 |
More Blazer parts colected for some day!
A board member posted about some blazer parts for sale on graigs list. I contacted the member and he said he was not interested but wanted to post if any one was. Wel as it turns out after thinking about what I need for my 2wd Blazer I thought I would go look at it at least and here is what I ended up getting.
I got both bed sides that are almost damage free and are 100% "rust " free. Yes they have surface rust but as you can see from one of the other pics 2 minutes with a DA 180 grit and the problem is gone The last owner sanded teh paint off or had it blasted and just never covered it up after wards. I will get it all soda blasted and epoxy sealed for later use. I also took the front of the tub because you can never have to many un-cut A/C dashes or "rust" free windshield frames for these Blazers. Again it will be blasted and epoxy sealed soon for later use if needed. The I got a set of truck door shells that are in great shape. The only damage is a few sets of mirror holes, now if I could only find someone who could weld I think I will have these blasted inside and out at the same time as the rest of the parts. Now I just need to trim down the front tub just to the part I want to hold on too and remove the bed sides from what is left of the floor. How do you like my hauling set up Also here are a few pics of my Blazer side's that need these donors bad. Kevin LFD Inc. Last edited by Rokcrln; 02-26-2007 at 09:08 PM. |
02-26-2007, 07:56 PM | #2 |
Re: More Blazer parts colected for some day!
A few more. Also I already have the dents dolly'd out of the bed sides. All of 20min work
Kevin LFD Inc. |
02-26-2007, 07:56 PM | #3 |
See see,there is a good use for a long bed
02-26-2007, 07:58 PM | #4 |
The bottom corner of the door was the worst of it and it is still great I think.
Kevin LFD Inc. |
02-26-2007, 08:00 PM | #5 |
02-26-2007, 08:02 PM | #6 |
Hey Kev, there outa' be a law, no man should have that many cool projects to work on. haha
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
02-26-2007, 10:05 PM | #7 |
Red-Neck wall ART what you alL think
Also just so I do not get tons of PM none of these parts are for sale! When my Blazer is done then we will see what was needed and what was not.. Also I am not taking names down for first in-line Kevin LFD Inc. |
02-26-2007, 11:11 PM | #8 |
SKINNY TIRES RULE!
Does this mean the Blazer project has been moved to the top of the list?
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
02-26-2007, 11:35 PM | #9 |
