Old 02-26-2007, 08:55 PM   #1
bbchevy
87 Wanna Be K30
bbchevy's Avatar
O2 sensor???maybe?possibly???
I put full length headers on my 87 and now it has no power. The truck barely moves when its cold and when its warmed up it bogs out really bad. I cant really drive like this. My 0-60 time is about 10 minutes. is it possible that i put the o2 sensor too far away when i welded the new fitting in? its on the exhaust, about 6in before the collector. i heard it needs to be with in a foot of the head. should i move it to a header tube?
thanks guys
-Scott
Was: 1987 V10 Silverado
TBI 350/700R4/208 with 3.42 gears
Is: A wanna be K30
330hp 350/465/205/D60/14FF with 3.73
hydroboost, 4 Core radiator, electric fans, Centerforce Duel Friction, Locker, 6inch Soft ride lift, etc....
bbchevy is offline   Reply With Quote
Old 02-26-2007, 11:28 PM   #2
HuggerCST
HuggerCST's Avatar
Re: O2 sensor???maybe?possibly???
thanks guys
-Scott
Good question. I wouldn't think that the location would affect it that much, but I guess it's possible. I just finished welding mine into the same place, but haven't finished installing the harness yet, so I haven't started it. I'm putting a 87 TBI & harness into my 85. I'll let you know how mine runs.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 02-27-2007, 12:56 AM   #3
bbchevy
87 Wanna Be K30
bbchevy's Avatar
Yea i heard the o2 has to be a certain temp to function properly. and making it that far away messes with it. that and the fact that it 30 degrees here so the exhaust doesnt get that warm in the first place, right now. i think im going to move it to a header tube.... but i really dont wanna move it
Is: A wanna be K30
Old 02-27-2007, 04:16 AM   #4
84slopwaggin
84slopwaggin's Avatar
I just installed headers on my 85. When I went to purchase reducers at the local speed shop some that they had in stock had the bung for the O2 sensor. I take it thats where it needs to go is in the reducer or maybe the collector itself. What type of headers did you install?
84slopwaggin is offline   Reply With Quote
Old 02-27-2007, 05:38 AM   #5
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
If it is a heat issue I would get a heated O2 sensor (three wire).
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 02-27-2007, 10:44 AM   #6
ChevyTech
The O2 voltage reading is not used to determine the fuel mixture during “Open loop” (cold) operation.
Anything else you can think of that you changed at the same time you put the headers on?
How stock is everything else?
True
With headers, I would only use a heated O2 sensor.
Old 02-27-2007, 10:48 AM   #7
HuggerCST
HuggerCST's Avatar
How should it be wired?
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 02-27-2007, 12:13 PM   #8
ChevyTech
Kits for retrofitting should come with instructions.
For the Three wire sensors:
One wire will connect to the same wire as the Old O2 sensor did.
Another will connect to power when the truck is running.
The remaining wire connects to ground.
Make sure you connect the correct wires to the correct places.
I would think there are other board members that have good information on this. Maybe even instructions, which came with theirs, they can post.
These sites show how 4 wire O2 sensors are wired on newer vehicles from the factory.
http://shbox.com/1/HO2S_connector.jpg
http://autorepair.about.com/library/...bl786a-lib.htm
Old 02-27-2007, 12:16 PM   #9
HuggerCST
HuggerCST's Avatar
Thanks!
Wynne
Build thread
53 Chevy shortbed
69 Camaro
