The 80 is home
Well we found out that it has a "Z" in the vin number. 350 diesel. It has a 350gas in it now. The fun part is going to be triyng to see what this motor is. Any tips on what to look for?
Trucks:86 GMC C15 Longbox , 05 Silverado 4x4 The other one: 89 Mustang LX In pieces, 93 Tempo |
Professional Grade
Re: The 80 is home
Take a pic, then we can tell you if it is a BOP, or a Chev
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
needin' money
Re: The 80 is home
the numbers stamped on the block
SWB Stands for Short Wide Bed |
![]() Join Date: Jul 2003
Re: The 80 is home
unless someone went to the trouble to covert it to a chevrolet, it is most likely a gas oldsmobile. If it has an oil fill at the front of the engine, and the starter on the drivers side, it is an olds motor.
Sb 400 club
Re: The 80 is home
any pictures? we all love pics
![]() ![]() 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed ![]() 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
Chevys Kick A$$
Re: The 80 is home
^Yeah we need some pictures. The numbers on the block will tell you.
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
Insert Witty Text Here
Re: The 80 is home
Most of the dead diesels got swapped to Olds engines because they are a direct bolt-in. The early GM diesels were based on the Olds engine.
Slonaker |
Re: The 80 is home
It's a Chevy small block. Shouldn't there be a number on the pad behind the alternator? It's getting yanked in a couple weeks and I'll see it all then. Thanks
Bulky
Re: The 80 is home
I think the easiest way to tell is the Olds 350 has spark plugs above the exhaust manifold and the small block chevy are slightly below the exhaust manfold ports.
Hope it helps.
2016 Silverado 1930 Model A Hot Rod 1923 Ford A/SR Altered - Injected 409 1982 Honda CB900F Super Sport Dad's 1970 GMC 9' Stepside Dad's 1969 GMC Custom Camper |
Re: The 80 is home
I have a 1980 that originally had a 350 diesel in it.. It had a 350 turbo tranny behind it and it was one of those tranny's that was generic. What I mean is it had all the gm bolt patterns on it.. I have had a olds, buick, and chevrolet motor in this truck all with the same tranny.. To my knowledge all pickups like this that came with the 350 diesel has this same tranny.. The main difference in converting between olds and chevrolet is the fuel pump and a/c unit will be on the other side..
#11 | |
Re: The 80 is home
Actually, I have seen the ac pump on both sides of the engine. My 79, has a radial compressor on the passenger side. My uncles 79 has a axial compressor on the drivers side. I am also pretty sure that most diesel pickups cam with the TH400 to handle the torque of the diesel, but I could be wrong. All three of the ex-diesel trucks we have have TH400. |
Re: The 80 is home
It turns out it has a 267 Chev in it. TH350 and a 12 bolt.
