Brake lines....
Im getting ready to run some brake lines all through the chassis of the shortfleet 4x4 before the cab goes on to save me some trouble.Do ya think I should spend the money and get pre bent lines or do it my self?What about stainless lines,yes or no?The truck isnt going to be a show truck but a nice D.D./weekend cruiser.Where do y'all buy the kits if you have pre bent lines and about how much does a kit run?Any other advice?....
Post Whore
![]() Join Date: Feb 2000
Re: Brake lines....
I bet you can do it yourself alot cheaper than a kit. Rent or buy a quality tube bender. I know I have read here some comments about the kits needing rebending to make them work. Definitely get it done before you start putting the sheetmetal back on - will be alot easier. I sure wouldn't waste my money on stainless steel for a d.d. The last ones lasted until now - the new ones will last a long time.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
The LuvShack Garage
Re: Brake lines....
I did not do all of mine, but I had to redo the Master Cyl. kit due to a leak,
it was 4 lines, they were pre-bent, they are Stainless, and I got mine from Tim at www.christiansclassics.com (They are not listed there, ya gotta call him at the store, but the number is toll free) I was very happy with the kit.
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
Aluminum slot wheels rule...
Re: Brake lines....
What do you need brakes for????
Re: Brake lines....
I dont want to nearly drive through the wall of the shop like when the m/c went out on the 69 4x4
Re: Brake lines....
You need to learn how to stop with the clutch, Dustin.
Re: Brake lines....
you can save quite a bit of money if you feel comfortable double flaring and bending the lines yourself// i'd buy stainless prebent from the master to prop valve and from prop valve to the frame then fab and bend the rest myself if i wanted to do a brake job that way getting the best of both worlds a cheaper price and the look of stainless where it's most visable in the engine compt
Re: Brake lines....
I agree with the "bend it yourself" crowd, at least you can know they will fit correctly. Don't forget good hoses! I got mine from xtremecrawlers.com as they are a Crown hose distributor (the best hoses hands-down).
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
The LuvShack Garage
Re: Brake lines....
The kit I bought from Tim is exactly what Cdowns described, it is the only
thing visible in the engine bay w/ out the use of undercarriage mirrors ![]()
#10 | |
67 is sold
Re: Brake lines....
I went stainless because I'm doing a ground up restoration. Anything else and I would have sent with standard steel lines for sure. Their customer service is A+ and everything fit like great with very minor tweaking by hand ![]() |
![]() Join Date: May 2003
Re: Brake lines....
I buy SS tubing & fittings and bend all my own lines. Your smart to do it before the body goe's on, it's much easier. If you buy SS tubing make sure it's the annealed stuff ( in a role ) the straight stuff looks nicer ( Very straight runs ) but it's very hard to double flare. Get yourself a quality flaring tool not a Walmart special.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
Re: Brake lines....
I used InlineTube in ss for my rear axle.It`s purdy,fit perfect,and comes with coil-wrap as oem.Through the frame is easy.But,I`d go all stainless on a totally new,all component,system and use a non-corrosive silicone fluid.The stainless doesn`t cost much more and pitting,frozen parts,and pinholes will be a thing of the past.Especially on a truck that sits a good bit.I haven`t seen a truck with all orginal hydraulics.
#13 |
![]() Join Date: Jan 2003
Re: Brake lines....
I bought the stainless kit from inlinetube, for my swb 4x4 and they fit great..... I'm with joe67
1972 Cheyenne K-30 6"lift {502 PROJECT} 1972 Cheyenne K-30 8"lift 454 450hp {Ol'Blue} 1972 Cheyenne K-20 Custom Stretch 6" lift 454 1972 Custom Deluxe K-20 4" lift 2007 GMC Crew Cab Diesel 6"lift {The Tow Rig 2017 Ford F-350 Crew Cab 6.7 6"lift (Wife's) 1977 El Camino SS Grandpa baught new 1986 K-30 Crew Cab 502 1955 Chevy 2-Door gasser 454 550hp{project} 1956 Chevy Bel-Air 2-Door hardtop 572 700hp 1979 Ford F-350 All Original 4x4 (Wife's) |
#14 |
Straight jacket required
Re: Brake lines....
Very good info--I'm at that stage too, with the cab off. Thanks everyone.
1968 C10 Short Stepper 350/350 A/C P/S P/B Front disc 3/5 static/ 12bolt rear 3:73 1979 Pontiac Trans Am 10th Anniversary/455/4spd 2011 H-D Street Glide - CAMMED n lowered Dad always said,"Son, if you can't be good...be good at it." ![]() |
#15 |
Junior Member
Re: Brake lines....
I just finished my brake lines. I bought the kit from inline tube. Very little modification was needed, just a little extra tweek needed at places. I would stick with OEM if it is not a show truck. OEM is alot better to work with. Easy to doulbe flare and manipulate if alterations are needed.
#16 |
Keep On Keepin' On
Re: Brake lines....
Do you have to redo the all the brake lines when you shorten a frame??
#17 |
67 is sold
Re: Brake lines....
I would think only the main line that runs the length of the frame has to be adjusted.
#18 |
67-72 Addict!
Re: Brake lines....
Another option for a non-show truck is the new stuff that NAPA has now!. It's a coated line that is bendable by hand!. Awesome product!!!!. You have to see it in person. My 2 cents.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
#19 | |
67 is sold
Re: Brake lines....
#20 |
67-72 Addict!
Re: Brake lines....
Joe, NAPA just got it in about 2 months ago. The manager told me a vendor at SEMA had a display and they were so impressed they decided to carry it. He handed me a brake line off the rack and told me to bend it like a pretzel. I couldn't believe it. The bends were smooth with NO kinks!. I tried finding it online on the NAPA site but couldn't. Try your local store.
#21 |
Re: Brake lines....
On a 2x4 truck with a small block or 6cyl, I would tend to bend my own. I just looked at replacing my front hoses on a 4x4 blazer----even hoisted up on my 4 poster lift, I could barely see the freakin hose to tube connection behind the exhaust, frame, linkage crap. I can't imagne trying to form/bend tubing to fit into those two areas without going nuts! If doing a restore, I would highly recommend replacing all the brake lines prior to installing body, engine, trans, etc.
#22 | |||
Union Electrician
Re: Brake lines....
3rd for inline tube prebent. I went with stainless because it lasts forever, and just looks really purrty. I also used their stainless ebrake kit as well. All parts a re top quality and their customer service is second to none!!
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
#23 |
C10 Club Tennessee
Re: Brake lines....
I'd be interested in those lines from Napa. I work at O'Reilly's but maybe I can get them through work with my discount. If anybody gets a name or manufacturer I'd appreciate it.
Dustin, I'm a cheapa$$ but I also know I have no patience so I'd probably go pre-bent like Luv said-Just where it is seen.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
#24 |
Re: Brake lines....
I asked the NAPA guy about those new lines and he hadn't heard of them yet. He suggested that I just use their 25ft roll of aluminized steel lines (easy to bend) and do it myself. They also sell straight runs with ends at different lengths. I am at this point as well so thanks for the advice. That inline kit runs $300+ with cables though...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#25 |
67-72 Addict!
Re: Brake lines....
The lines at NAPA are called polyarmor but I couldn't find them on their website.
