hard line info
Can anybody tell me the details I need to know to run hard lines on my airbag system? What type of fittings do you use for hardlines? Would the fittings be different if I went with steel vs stainless? Do you use thread sealer with hardlines? Where can I get the lines? Would it be better to find a place that carries straight runs vs a roll? And if anybody has pictures, that would be great.
Re: hard line info
well most people have been useing plastic lines but i dont see why you couldnt use steel just more work to bend
Chevy Truck Addict
![]() Join Date: Aug 2006
Re: hard line info
A buddy of mine ran brake line for the air system on his truck. I will check with him to see if he did anything special with the fittings.
. 1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD) 1978 Chevy C/10 SWB 1970 Pontiac Lemans . |
Re: hard line info
they are just flared fittings. it is a pain to bend though. i just did some 1/2" fuel line over the weekend.
69 4wd V6 20k orig miles!! ![]() 05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored. ![]() 01 rcsb chevy 2wd 6bt cummins :devil:> build xtremediesel.com |
Re: hard line info
anybody have a link to the fittings needed?
Re: hard line info
http://www.russellperformance.com/
that should help
Re: hard line info
you will want to you use a seemless stainless line
Re: hard line info
Does hardline and/or fittings in an airbag system need to be stainless?
