Old 02-27-2007, 07:48 PM   #1
smoknbarrels
Registered Mail
smoknbarrels's Avatar
How Long is Your Shaft?? (All 1 pc. Drive Shaft Guys)
I am putting a super T-10 4 speed in a short box and want to go to a 1 Piece Drive shaft, is there any other vehicle that out there that will be the same length I can steal one from? what does yours measure?
smoknbarrels is offline   Reply With Quote
Old 02-27-2007, 07:56 PM   #2
Pl4yboy
Freeeeee Mason...
Pl4yboy's Avatar
Re: How Long is Your Shaft?? (All 1 pc. Drive Shaft Guys)
Hmm I saw the name of this topic and my mind went straight to the gutter... Sorry I can't help, but great way to get attention.
Pl4yboy is offline   Reply With Quote
Old 02-27-2007, 08:38 PM   #3
Ram-Man
Ram-Man's Avatar
Thats kinda of personal isn't it. But it got my attention Who has a 1 piece LWB shaft?? That is what I hope to do.
Ram-Man is offline   Reply With Quote
Old 02-28-2007, 12:04 AM   #4
Jayss109
Active Member
Jayss109's Avatar
just get one made custom. Its not worth the effort to hunt and search for one that "might work". I got mine made for $220 iirc, brand new, yolk and all
Jason
Jayss109 is offline   Reply With Quote
Old 02-28-2007, 12:16 AM   #5
ClassicRedneck05
ClassicRedneck05's Avatar
i have a LWB 72 Chevy i have a single shaft and i can measure mine tomorrow if you still want a measurement
Redneck Rampage
1972 Chevrolet C-10 LWB 350
1972 Chevrolet K-20 LWB 502 LiFtEd
ClassicRedneck05 is offline   Reply With Quote
Old 02-28-2007, 01:30 AM   #6
firedog
firedog's Avatar
i was told that a small block mounted in the foward holes with a 350 turbo tranny requires a drive shaft of 60" from end to end (including the shaft and the loops on each end) on a short wheel base truck. the same reliable person told me it was only available in a 6 cylinder short wheel base truck all others had 2 drive shafts hope that helps
*SOLD*
1968 Chevy SWB Fleet
350/350 combo
Tach/tilt/buddy buckets
Bagged/18" Wheels
Black on Black
Project "Pandemic" the Farm Rat
1927 Chevy Capitol Truck Rat rod
'30 Model A Frame
Dual Carb 5.3 LS
http://www.67-72chevytrucks.com/vboa...d.php?t=804162
2007 GMC 4 DOOR 2WD
BUILT 5.3 STAGE 3 CAM 93 TUNE
LIFTED 22X12 WHEELS 33" TIRES
2023 Jeep RENEGADE
Wifes ride
firedog is offline   Reply With Quote
Old 02-28-2007, 09:08 AM   #7
Mine is too short,but don`t tell anyone.The best thing is to get it all mounted and measure.Go to shop with your shaft in hand and tell them what you need.
Old 02-28-2007, 11:49 AM   #8
smoknbarrels
Registered Mail
I was afraid that I may need a custom one, since oil is boomming in Alberta labour rates are killer, it"ll be about $150/hr to get one built.
i guess I'll have to slap it together and measure it up..
but how much slack do I need on the output shaft to allow for suspension travel or movement?
Old 02-28-2007, 11:58 AM   #9
shifty
Questionable
shifty's Avatar
I want to say that mine was 71" from end to end (i.e. center of u-joint on yoke to same on other side). This was on an inline 6 with 3spd on tree. Just so happened to be a perfect fit for my LS1 + T56 as well - who'da thought?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 02-28-2007, 04:16 PM   #10
For play,figure fully extended to fully compressed measurement.Let`s say it`s 4" of movement,divide that in half...2" and you`ll be good.That`s what the guy that handled my shaft told me.
Old 02-28-2007, 05:19 PM   #11
shifty
Questionable
shifty's Avatar
Easy way to measure what you'll need is to take both yokes and insert them fully into the gearbox and tailshaft. Slide them each out 1" and measurefrom the center of one U-joint provision to the other.
If you can get this measurement, any driveshaft within 1-2" of that length should suffice, as long as your U-joint is the same size.
Old 02-28-2007, 05:28 PM   #12
Orange
Licensed to Thrill!
Orange's Avatar
Here's what I can tell you from this weekends experience installing my 700R4...
The driveline shop I used wanted the measurement from the tailshaft seal on the transmission to the centerline of the rear-end yoke. For me, with the 700R4, this was 58-3/4".
If you want my driveshaft dimension, just tell what exactly you want (center to center, etc.) and I can get it...it's in the truck, but simple enough.
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
