cracker
is this true?
My dad told me now that i have the lift, i should go with some 35s or 37s, that it will help me to get better gas milage, because it will be like having highway gears, instead of the ones ive got, i dont know ifthis is true or not (ithin ive got 4.11)
FOUNDING MEMBER OF THE DRUM BRAKE CLUB Harry John Albert III located in Phoenix, AZ 1972 GMC JIMMY, 1969 lwb Chevy Frame, 1999 bmw k1200 ltc 1992 Kawasaki concours 1991 bmw k75 1973 cortez motorhome |
CCRider
At a steady speed cruzing they should help some because of the larger diamiter, but lots of times putting on a larger tire can hurt city milage because it takes more to get the heavier tire moving from a stop.
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
So Many Ideas, So Little Money
Tom said it just how I'd think it'd be..
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu ![]() Marshalltown, Iowa |
KEEP IT PINNED
What size tire do u have now?
WTF
Yeh if you go to a bigger tire it would be like less gearing it may drop to like 3.73. If you went to a smaller tire you would gain gearing like to a 4.33. There is a formula doe a search for wheel and gearing and you should find the info you need. This is kinda in the same ballpark, when I was 17 we changed my rear in the camaro from a 2.73 single to a 4.56 posi talk about a different world.
Some people are wise, some people are otherwise. 72 cheyenne primer factory air lowered rallyes with flat caps flowmasters 12 bolt 3.73 350/350 combo needs rockers . Cowl hood installed. 81 Malibu wagon lowered with 17's bright ass yellow and v-6. 71 225 Electra all original 455/4 81 z28 |
cracker
right now i have 31s, and they are way to small
Just here to help
![]() Join Date: Jan 2002
I went from 31's to 38's on the burb and the mileage dropped about 4 mpg,i have 373 rear end.....hope this helps..........James
