Cab interchange
Will a 67 and 71 cab interchange
Weekend Warrior
Re: Cab interchange
Yeh they'll all interchange, but the mirror may be attached to the W/S instead of bolted to the header in the cab.
the E-brake may be a hand operated in the '67 and foot operated in the '71 Make sure that if you currently have a "high hump - bolt in center floor" that the replacment is the same - you can make a "low hump" a high hump but it takes a little work.
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() |
Re: Cab interchange
The other area of difference is the throttle linkage. The 71 uses a cable and the 67 uses a rod. The 71 should fit the carb with only a stud added.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
its all about the +6 inches
Re: Cab interchange
it'll work, but not a 100% direct replacement.
The parking brake is the foot kind, not the hand type, and it'll be a HUGE hassle to swap out. The fuse box/harness/dash switches are all different from yours... again, I'd just run the new stuff. The throttle will be cable instead of rod... safer, but probably needs a new cable. |
