Old 02-28-2007, 09:36 AM   #1
jdhcth
jdhcth's Avatar
Clutch rod rubbing on headers
All,
67' LWB 283 3 Speed Saginaw. Gotta pair of Hedman HED-69092 full length headers. The clutch rod rubs on the rear pipe below the 90. Anyone else have/had this problem? Any cures, like an 'offset' cluthrod or maybe pounding a dent in the header to make space???
Thanks,
JD
jdhcth is offline   Reply With Quote
Old 02-28-2007, 09:53 AM   #2
cdowns
cdowns's Avatar
Re: Clutch rod rubbing on headers
just smash the pipe for clearance a common practice and little to no performance effect on the header
Old 02-28-2007, 03:05 PM   #3
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
try turning the rod the other way around i did on mine it has about 1/4 in clearance
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 02-28-2007, 03:10 PM   #4
shifty
Questionable
shifty's Avatar
I had the same problem with my headers on my inline. I did what cdowns suggested - took a ballpeen and "massaged" a path for clearance. No ill effects.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-01-2007, 05:39 PM   #5
phlegm
Still Green but learning
phlegm's Avatar
I think I saw a post somewhere about linkage adjustment.... they drilled a 2nd hole where the linkage makes a turn there and then trimmed the rest... but find the post as most can attest I like to make things up just to sound helpfull ;-)
-- Cory
71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab
07 Suburban LTZ 4x4
2010 Acura TL
98 Mastercraft "FrankenStar" 225
27253 UPS/USPS
IIOY....nope never was
phlegm is offline   Reply With Quote
