Old 02-28-2007, 12:25 PM   #1
phlegm
Still Green but learning
phlegm's Avatar
Carb Rebuild
I have a small fuel leak in the carb that needs to be addressed at some point.
I found this after searching,
http://67-72chevytrucks.com/vboard/s...uretor+rebuild
It is helpfull with links, I guess my question is seeing as I have never re-built a carb before would it be worth it for me to find one rebuilt and purchase, or maybe a new setup? Any recomendations on low to med priced performance setups?
-- Cory
71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab
07 Suburban LTZ 4x4
2010 Acura TL
98 Mastercraft "FrankenStar" 225
27253 UPS/USPS
IIOY....nope never was
phlegm is offline   Reply With Quote
Old 02-28-2007, 01:44 PM   #2
don t. - 72gmc
Re: Carb Rebuild
Where's the leak? Tween the 2 halfs? A hole punched in the side(grin)? Im assuming your talkin bout a 4 bbl q-jet.
They aint hard to rebuild, and Im no mechanic. There should be instruction in the kit. Between them, the link, and the sites in the link, you should be good to go. Keep things clean, take tons of pics that you can reference when you forget how its goes back together (big grin).
HTH....good luck.....don t. .....
don t. - 72gmc is offline   Reply With Quote
Old 03-01-2007, 05:27 PM   #3
phlegm
phlegm's Avatar
Re: Carb Rebuild
I found one for $147.99 on line at Autozone.... no work space (just moved to an apt) no time (I have 2 little ones and am finishing up a move)....
this may be another good option.... I was looking forward to getting greasy, decisions decisions.
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 03-01-2007, 07:50 PM   #4
71chevytruckguy
71chevytruckguy's Avatar
Re: Carb Rebuild
where in nc are you at? i might be able to help you with your rebuild if you ain't too far?
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 03-02-2007, 09:18 AM   #5
phlegm
phlegm's Avatar
Re: Carb Rebuild
Not far at all. I am in Mebane NC, My wifes family lives in winston. I appreciate the invite, the carb isnt a huge issue now so after things settle on the move I will pm you and if you have time I would really appreciate the help!!
thanks...... This is such a great community.
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 03-03-2007, 11:01 AM   #6
wnc mountain
More hobbies than money!
wnc mountain's Avatar
Re: Carb Rebuild
Dude, come on over. We'll have that thing rebuilt in an hour!
'70 cst10/swb 350, 3 on the tree, factory buckets.
'70 GMC lwb 350/350 ps,pb
'72 c-10 lwb 350/350 a/c, ps, pb
'72 Blazer project
wnc mountain is offline   Reply With Quote
