02-28-2007, 08:51 PM | #1 |
Gray Bucket Seat Belts-Centers F/S
Not sure of a better title to describe these? They will fit in Blazers, Burbs and probably trucks with buckets. Came from a '90 Burb. Clean with a very small split on either, one split at the top of the passenger belt, 1/4 " and driver's belt has a split on the bottom near the floor mount. Driver's belt has wire harness with good connector for seat belt warning buzzer if desired. Mounting bolts and caps included. If closer pics of splits are needed can do. Not show but a strong 9 + on a 1 - 10 scale. $15 plus shipping.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks Last edited by Ironhorse; 11-06-2007 at 09:53 AM. |
03-10-2007, 07:17 PM | #2 |
Re: Gray Bucket Seat Belts-Centers F/S
ttt
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
03-13-2007, 08:55 PM | #3 |
Will these still "stand" by themselves?
On my '82 K5 the plastice is broken so the belt falls down between the console and the seat - getting a little old having to dig around every time I get in. Are you sure these will work on a Blazer?
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
03-13-2007, 10:03 PM | #4 |
Yes, they still "stand" up right by them selves. The plastic sleeves are unbroken with two very minor 1/4" splits, one on each plastic sleeve as mentioned. I pulled these from a '90 Suburban but I would think they would be the same application for a Blazer or Pickup with buckets and console.
