03-01-2007, 12:52 AM | #1 |
how do you remove light socket from front turn signal?
how do you remove light socket from front turn signal? my bulb is not making good contact. and i think i need to replace socket.
thanks |
03-01-2007, 12:57 AM | #2 |
its all about the +6 inches
Re: how do you remove light socket from front turn signal?
push and twist counter clockwise
03-01-2007, 06:48 PM | #3 |
Andy - I think he is asking about the socket itself. Best way is to buy a new (another) turn signal bucket. The socket is crimped in place to keep water and roadgrime away from the wires.
Try to clean the dirt/corosion with a small pick or file. You might be able to get it clean enough that way.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
03-01-2007, 07:09 PM | #4 |
Doh!
03-01-2007, 09:52 PM | #5 |
thanks guys. you right bob. im speaking of socket. it just doesn't seem to be making good contact goes out when i shut door or hit bumps. im gonna try a wire brush first.
