03-01-2007, 12:29 PM | #1 |
69 -71 vs. 72
What is the difference between the 69-71 and the 72.
I know the doors are diff. but what is the diff? And is there any other differences. thanks |
03-01-2007, 01:11 PM | #2 |
Re: 69 -71 vs. 72
The length!
03-01-2007, 02:16 PM | #3 |
Future TOTM Winner
Re: 69 -71 vs. 72
There are a few small differences, most of the same stuff that changed with the trucks also changed with the K5. For instance, 72's had a rearview mirror glued to the windshield, the older models had it bolted to the metal frame above the windshield. The window cranks and door openers have a longer shaft to fit through the different door panels that came along in 72 (in other words, the newer panels are “thicker” and the hardware had to be lengthened). Then there is the additional screw on the inside of the doors that braced the vent windows, but I think some of the 71’s had them also. Oh, yeah, 71 had a black trim stripe around the grill, 72 was all chrome. There are other details from the 71 to 72 change, I’m sure more people will chime in and help out, those are just the most obvious to me. Maybe someone will even provide pictures.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com Last edited by Critter; 03-01-2007 at 04:36 PM. |
03-01-2007, 02:33 PM | #4 |
SKINNY TIRES RULE!
Re: 69 -71 vs. 72
All first Gen Blazers had the same length, width, height, etc.
All '72s had front disc brakes - they were optional in '71. Double wall top was also available in '72. Interior door panels were molded plastic. Seat patterns were different for 71-72.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
03-01-2007, 04:29 PM | #5 |
Re: 69 -71 vs. 72
Maybe he meant 69-71 is longer than 72.(5 spaces vs. two)
03-01-2007, 05:34 PM | #6 |
SKINNY TIRES RULE!
Re: 69 -71 vs. 72
Took me like 5 minutes to figure that one out. Sometimes, I'm just a bit slower than the rest.
03-01-2007, 06:14 PM | #7 |
I'm a poor spectator
Re: 69 -71 vs. 72
I have a double wall top so I don't think it was just a 72 thing.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! 1979 Ford F150 4x4 SWB Built Ford Tough!!! 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
03-01-2007, 06:41 PM | #8 |
Future TOTM Winner
Re: 69 -71 vs. 72
Yeah, but what does your glove box tag say? Doesn't it distinguish between double and single wall top, also color? Maybe I'm wrong.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
03-01-2007, 06:46 PM | #9 |
Re: 69 -71 vs. 72
Gas filler neck,69-70 and 71-72, also throttle linkage 69-70 and cable 71-72,
70 Jimmy 4x4 71 GMC 2500 Too bad stupidity isn't painful |
03-01-2007, 08:01 PM | #10 |
Re: 69 -71 vs. 72
Hey,I don`t know.Just my attempt to make sense from it (from left field).I really doubt that`s where he was coming from. I think he got the cut-off year wrong and meant`73-up.Now I`m thinking of a Supremes song from the Motown days:Jimmy...Jimmy...oh Jimmypop when are ya coming back? Welcome to the site,man.No body`s perfect,especially us misfits.(I should just speak for myself).
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 03-01-2007 at 08:05 PM. |
03-01-2007, 08:02 PM | #11 |
Re: 69 -71 vs. 72
I was under the impression 71 is when all models came stock with disc brakes up front.Are the blazers different
Last edited by 1969k10stepside; 03-01-2007 at 08:03 PM. Reason: Subject verb agreement was incorrect :) |
03-01-2007, 09:31 PM | #12 |
Active Member
Re: 69 -71 vs. 72
Single wall tops were available on the second half run of the 72 model, double walls were used on them as well. from what I was told, GM was prepping for the 2nd gen Blazers who has the single wall design only
03-01-2007, 09:43 PM | #13 |
Re: 69 -71 vs. 72
so can you use 72 door shells on a 71 2wd thanks
03-01-2007, 09:47 PM | #14 |
Re: 69 -71 vs. 72
Yes,they can be used
03-01-2007, 11:30 PM | #15 |
Re: 69 -71 vs. 72
If your meaning all vehicles, they were different for each model. Some GM cars had disc as standard eqipment earlier than others. Nova and other similar vehicles didn't get away from drum brakes till 75, allthough it was an option.
03-01-2007, 11:35 PM | #16 |
Re: 69 -71 vs. 72
I meant as in the trucks,burbs,blazers,and jimmys.
03-01-2007, 11:57 PM | #17 |
Re: 69 -71 vs. 72
You`re right,Dustin...`71 for discs on all trucks,Burbs,Blazers,Jimmys,Panels,2 and 4wd.
