Old 03-01-2007, 01:34 PM   #1
oveeets
dash wires ???
I'm under my 69 burban trying to clean up wiring ...couple wires that i can't seem to find a home to..
on the back of cig lighter there's a red power , lt.blue to light socket , and a wire connected to the housing but the end of that wire was not connect to anything??? possible ground of connects to something else that shares the ground ???
steeevo
STEEEVO 69 BurB
oveeets is offline   Reply With Quote
Old 03-01-2007, 01:45 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: dash wires ???
some one probably had a stereo in there and grounded it to that wire. Maybe some guages that used to hang under the dash.
Not stock, and there SHOULD be no reason to keep it.
Old 03-01-2007, 02:29 PM   #3
BigSky71
LAIDOUT
BigSky71's Avatar
Re: dash wires ???
I have replaced my harness now, but the first time I cleaned up my dash wiring, I pulled several dozen feet of wire out from under my dash. All I can figure is that Gramp's 8 track needed 10 wires to run it, ha ha...
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
Old 03-01-2007, 08:29 PM   #4
sjarrett71
sjarrett71's Avatar
Re: dash wires ???
Same problem here, miles of "extra" wire. I'm not necessarily into keeping things stock but I like to keep things clean. It makes you wonder what some people think when they work on vehicles. My whole dash harness was cut off and then replaced. Someone used wire nuts to connect everything. Now I'm looking for a good used dash harness or I have a lot of splicing and soldering in my future.
-Scott-
sjarrett71 is offline   Reply With Quote
