Old 03-01-2007, 03:49 PM   #1
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
What does a stock 72 sbc air cleaner assy. look like?
Can someone post a pic of a stock air cleaner assembly for a 72 Chevy or GMC truck? I think I have one and would like to get rid of it.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 03-01-2007, 04:59 PM   #2
68speedalert
Semi-Senior Member
68speedalert's Avatar
Re: What does a stock 72 sbc air cleaner assy. look like?
What engine and carb?
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre
'83 Jeep CJ-7, <80,000 miles, original owner
'04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer
'95 GMC K1500 Extended cab
68speedalert is offline   Reply With Quote
Old 03-01-2007, 07:27 PM   #3
724x4a/cchevy
Self-proclaimed LED man
724x4a/cchevy's Avatar
My LED Website
My Photobucket Album of LED's
Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK
I also do LED:
-Third Brake/Cargo
-Brake (truck and burb)
-Reverse (truck and burb)
-67-68 Front Turn Signals
-69-70 Front Turn Signals
-71-72 Front Turn Signals
-GMC Front Turn Signals
I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once
Norwood Survivor
724x4a/cchevy is offline   Reply With Quote
Old 03-01-2007, 09:01 PM   #4
stomper
Junior Member
stomper's Avatar
There are at least two designs. I bought an air filter element at the local auto parts store the other day and found there were at least two different elements available. '72 K5 Blazer element is a little taller than a '71 2wd 3/4 ton. I found out because the air cleaner tub I have came off a '71 3/4 ton 2wd truck (GMC I think). When replaced, I usually get an element that is taller than stock to hold the lid off the base and allow a little more air in. The one I picked happend to be correct for my K5 but held the lid too high - wouldn't fit under the firewall overhang. We double checked part numbers and sure enough, the one that fit was for a '71 3/4 ton. I guess the base or tub is deeper on a K5 and shallower on a 3/4 ton truck?
"I was patina when patina wasn't cool."
1973 Cheyenne SWB Sunset Gold / Frost White / Saddle
stomper is offline   Reply With Quote
Old 03-01-2007, 09:51 PM   #5
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
The truck originally came with a 350 and a Qjet carb, and is a 72 GMC 2wd long bed.
72 4x4- the pics you have posted looks just like the one that I have. Are there any GM part #'s on the assembly that I could look for to determine exactly what it is for? I will probably be listing it on ebay soon. Thanks!!
