18 Till I Die
Metal Glove Box
A fellow board member (Frizzle Fry) PMd me and asked if I could make a metal glove box without the radio side. More like an original replacement. So here we go...
I made a glove box out of 22g galvanized steel using some measurements from my sample dash. I had to see if it would go in in pieces. I didnt want to assemble it and then it didnt fit. Once it went in I put the ends on and then I seen if it would fit thru the hole, and it did. BUT I dont know if there is enough room to get it in on a truck. My dash is on the bench? Heater box might be in the way.
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... ![]() Last edited by kelsfine69; 03-01-2007 at 11:05 PM. |
Re: Metal Glove Box
looks good
18 Till I Die
Re: Metal Glove Box
Next I pre-drilled the ends after marking the holes, Using the two factory holes on each side. and mounted it up.
OK guys Opinion time ![]() Frizzle Fry...Is this what your talking about?
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... ![]() |
![]() Join Date: Aug 2005
Re: Metal Glove Box
Yep. Perfect!
its all about the +6 inches
Re: Metal Glove Box
that is much nicer than how mine came out.
I took the soggy cardboard one out, and unstapled it, traced it out on some thin sheet metal, cut it out and folded it into shape. You'll want to toss a piece of carpet, or something to keep everything from rattling. It'll drive you insane. I used 1/16 inch rubber in mine. |
18 Till I Die
Re: Metal Glove Box
Now is this metal ok? or would the Aluminum be better? The aluminum would not hold the shine very long and it might be harder to get in? I do have some aluminized 22g at work maby I should make one of those?
#7 | |
![]() Join Date: Apr 2005
Re: Metal Glove Box
Cool idea!!
R
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 03-01-2007 at 11:04 PM. |
18 Till I Die
Re: Metal Glove Box
I bet Home Depot or whoever would have tons of ideas for a bottom liner. How about that thin black toolbox liner?
Re: Metal Glove Box
sears would have that too.
I wouldn't do an abrasive liner, it sucks skinnin your knuckles gettin the registration and proof of ins for the cops. |
Re: Metal Glove Box
I was thinking about using a coating on it too. I just want something solid to mount my Omnifi (mp3 hard-drive) to. Right now it's just sitting in there.
Re: Metal Glove Box
You know, I guess a metal glove box is a nice touch, those cardboard ones are a little cheesy, but the only reason I would go to that trouble is if I was going to put a bowling ball in there or something - don't misunderstand, it's a nice touch, but maybe a tad overkill -?
#12 | |
Re: Metal Glove Box
![]() seriously, when i read your other post earlier today, i was thinking that i should ask if you could make this very thing... Damn I'm good ![]()
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill Last edited by brak; 03-02-2007 at 12:47 AM. |
#13 |
SLOW BUT SURE,BUT CLOSER
Re: Metal Glove Box
Good idea, but when the factory ones last for 30+ yrs how long would a 10-15$ repop last?
69 C-10, OWNED 35YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS....... ![]() ![]() ![]() |
#14 |
Re: Metal Glove Box
very cool - I would think if you spray the outside (hidden) with say...undercoating or even wrapped it with dynamat, it would reduce any rattling to about nil and you wouldn't have to line it with anything except maybe some nice epoxy paint... or some of that "splatter of colors" type paint you see under the carpet of the old cars trunks....
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
#15 |
Re: Metal Glove Box
It looks good, but I see one big problem. The bottle of Crown Royal is empty!
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! ![]() 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! ![]() |
#16 |
Re: Metal Glove Box
I like it!
Ya gonna bild more?
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
#17 |
Re: Metal Glove Box
Hey Kel.....Is the Crown Royal an integral part of the manufacturing process?
![]() ![]() ![]() ![]() Looks awesome. As usual.
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
#18 |
Page intentionally left blank.
![]() Join Date: Jul 2006
Re: Metal Glove Box
If it takes a bottle of Crown to make every one, this is going to be very expensive to mass produce... and that's before considering the hangover!
There is a theory which states that if ever anyone discovers exactly what the Universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarre and inexplicable.There is another theory which states that this has already happened. - Douglas Adams '67 GMC 4x4, 305 V6! Or all the parts for anyway... '17 Subaru Outback. '18 Toyota Tacoma TRD Off Road. '99 Ducati 900SS. |
#19 |
18 Till I Die
Re: Metal Glove Box
Hey you guys are funny
![]() ![]() I made a new one today out of "Galvalume". Kinda a aluminum coated steel. . I will post some pics later.
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... ![]() Last edited by kelsfine69; 03-02-2007 at 07:21 PM. |
#20 |
Re: Metal Glove Box
I did the same thing for a customers truck. I welded mine up and painted it black. I was able to fit it under the dash and in. When we get to the point of carpet, I plan on lining the whole glove box with carpet too.
#21 |
![]() Join Date: Jan 2004
Re: Metal Glove Box
If you can make a metal glove box for a A/C truck I'd buy one. Please send me a message if this ever works. I'm very interested.
#22 | |
![]() Join Date: Apr 2000
Re: Metal Glove Box
nice job..
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
#23 |
Re: Metal Glove Box
I have thought about doing the same thing but it will be notched out for the A/C ducts so about 1/3 of the space will be lost. Nice job!
Kevin LFD Inc. |
#24 |
Re: Metal Glove Box
Now, I've only owned 3 trucks, and 2 of them were pretty well beaten by the time I got them, but my first one was pretty decent... a good 7 or 8 outta 10. However, none of them had good cardboard glove boxes... one was mising, the other two were torn up, sagging, and falling apart. I thought the cost (free scrap) was good, and the time spent on it was good. The only part I didn't like was cutting my finger real bad and bleeding.
#25 |
18 Till I Die
Re: Metal Glove Box
Heres the Galvalume one I made Installed. This material has a nicer finish to it. Im going to check out Home Depot today for some liner ideas
