My temp light flickers on and off on my '67 Chevy. Loose wire? The aftermarket temp gauge says 190degrees and it just started doing this...? I don't see any pattern but it seems to flicker most when reving the engine, at a steady speed/rpm the light just stays on. What does this mean?
I've got an ammeter on here that is not hooked up. Not sure what wire goes where, never hooked one up before. Does the reading wire go to the output of the alternator?
http://4.65.252.68/hosted/twilightsig.jpg 1967 Chevy Pickup: '85 Camaro 305 Rebuilt carb - Turbo 400 Trans Flowtech headers to Purple Hornies |
its all about the +6 inches
Wecome to the forum.
On your dummy light, since you have a guage also...I would just remove the bulb from the light. As far as your bat. guage, the small wire coming off the pos i=on the batt, you run that to your guage, then run another wire from the other side of the guage back to the battery. ------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
I know a VOLT meter is hooked up that way, didn't know it was the same for ammeter (amps)???
They are diffrent. An amp meter is hooked up to the alternator. Amp meters are dangerous (thats why people don't use them any more. they use Volt meters instead). An amp meter needs to have that large wire comming from the alternator comming through the fire wall. If there is ever a short, you have major car fire / meltdown! I wouldn't use it. Just my opinion. They do have a shunt system (for safety), however, I still wouldn't use one. Sorry I don't have details on exactly what wire goes where. Darren
Washington State 1967 Chevy C10 LWB Rodstoration In Progress. 1972 K20 Cheyenne Super |
The volt meter is run from positive to guage to ground.
The instructions to my amp guage says to interupt the smal wire going to the battery. ------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
Twilightopics, I would go by what Longhornmail is saying. My experience is with older style Ammeters. And Longhornmail seems to have a newer style guage, and good instructions. Darren
Well I did forget to mention...aftermarket guage here. Sorry.
