My PO post rant!
I thought I wouldn't say anything about my '70 c-10 that I bought on eBay, but it is getting to a point of frustration that I can't deal with. When I went to get the truck, the hood would not open, PO tells me it's a broken driverside hood hinge. We get the hood open and everything in the engine compartment looks fine. He starts up the motor and it sounds killer! He knows I live 30 miles away, looks me in the eyes and tells me he'd drive the truck anywhere. The truck is straight and no rust so I pay the man and head for home. I start the truck, put her in gear and away I go happy to score a swb fleetside.
1) I go to replace the hood hinge with a good used hinge I have. I remove the hinge at the hood no probs, I remove the bolts on the fender and two come out OK, but the third one (which is a silver grade 5 bolt from the PO) has a detached weld nut and spins freely. Great a 10 minute job turns into a 1 hour job. Finally have to chisel out the third bolt. Install the the hinge,I'm pissed but the job is done. 2) I go out in the morning and there is a puddle of tranny fluid under the truck, what now! Turns out the tranny is leaking from the front and rear seals, OK I say, some members assure me it's an easy job and it's not too bad, but a Saturday is shot to hell. I say to myself no prob jst a little work to get the truck roadworthy. 3) I drive to truck to home depot and the drivers window goes off track and the passenger window is stuck closed. Turn around and go home, driver and passenger regulators are shot and the vent windows are crooked. I open the vent windows and they won't close. I say to myself, you should have checked the window operations before you paid the man, my bad. The windows are so heavily tinted, so I replace the door windows, vent windows and regulators with some used ones I have. This takes the good part of the day since some screws are rusted in the vent window and regulator. Chiseling, drilling and retapping, I'm good to go. 4) I want to replace the late model bucket seats back to a stock bench seat. I look at the bottom of the bucket seats and the PO used black pipe as spacers between the seats and the cab floor with some cheap bolts which he drilled through a pristine floor. I thank God that the bolts didn't snap as I was driving to work, and go to remove the bolts. The outer bolts by the doors are cake to remove, but the innners are not accessable because the rears are right at the trailing arm crossmember and the fronts are on top of the flow masters. Out comes the sawsall, and with the vengeance of an ancient samuri I cut those suckers out. The seat have back pockets and in these back pockets have to be about 30-40 condoms (brand new in the package). Disgusted I throw them away, and then the wife comes in later asking me where those condoms in the trash came from, I tell her, but I can tell by the look in her eye she is either pissed because I didn't check the truck before I brought it home from the PO or she thinks I'm a freaking perv. The only good thing to happen is that the stock bench goes in without a hitch. 5) I drive the truck to work, park in a great spot. Go to lock the drivers door and the tumbler won't turn. It was working fine, but of course it is not working now! I'm so pissed, I just leave the truck unlocked the whole day not caring if someone steals the truck. Get out of work and there the truck is, giving me a sh!~-eating grin. I go home and replace both locks with with a used set I have at home. I think OK, it will get better. After all I haven't had to buy any parts, and I'm slowly cleaning out my parts stash so maybe it's a good thing. 6) Driving to work on a rainy morning and the cab windows fog up (probably because I'm nervous as hell wondering what is going to fall apart next.) I turn on the fan switch and it works! I Go to the AC/Heater controls and set the bottom lever (good), set the middle lever (good), go to move the top lever to defrost and without even applying hard pressure the lever breaks and falls to the cab floor. I can't see out the windsheild now, pull over and want to cry. I tell myself, it's a classic truck that just needs some lovin'. I have a clean rag, so I wipe the window at every stop light and make it to work. 7) The truck is a little to low for my taste, so I decide to replace the springs with some extras. As I jack up the truck I notice I have a three piece drive shaft! From the tranny, it's driveshaft, tranny yoke, drive shaft. Now this is where I lose it. There is no carrier bearing! There is a piece of folded over cardboard wedged in between the yoke (which is in the middle of two driveshafts) and the cab floor. Seems that when they lowered the truck the drive shaft wouldn't work with the carrier bearing so they removed the carrier bearing. OK cardboard! Give me a freakin break! I go to sit in the truck and ponder what my next move is and the button from the driverside door handle pops out! I reassure myself that I have the parts just sitting in the garage, so it hasn't cost me anything other than time, but I'm pissed off at this guy. I' afraid to go to Pomona this weekend, because if I see this guy I'm gonna dot his eyes and get arrested. Now it's gonna cost me more some good cash to get a driveshaft built. With what I paid for this truck, OK maybe I'm a sucker. But with the guy going on about how he is a religious man, his truck is this classic collectors item, its turnkey ready to go/show, and yet he jerry-riggs everything WTF! On the plus side I have a straight truck with no rust, yet. Although for what I know of this guy it's all probably bondoed. There are other issues like a mile of wiring under the dash for the stereo and door poppers/locks. (none of which works.) Theres a 4 gauge wire running from the engine compartment to the rear of the cab? There was enough white powder battery to look like a winter wonderland under the battery tray. And as a final last straw 8)My wife says there is another puddle under the truck, this time it's power steering fluid on my new cement slab. The wife hugs me, pats my back and says it's going to be alright. The wife is cool that way. Sorry but I just needed to rant, to some guys and gals who probably know to some extent the pain I feel. Moral: never buy a "restored show" truck without doing a 100 point checkup on the truck. You'll be glad you did. I feel better now, so I'm going to install the springs, measure for a new driveshaft and fix the power steering this weekend. Hopefully next week it will just be a bad memory, until I discover the next PO mistake. I hope someone can learn from this and not make the same dumb mistake I did. Wow is this what therapy is like?
![]() ![]() It ain't yours, if you didn't build it! |
Black 72 Chevy
Re: My PO post rant!
Man that sucks.
72 Chevy, SWB, 350engine, TH400 |
![]() Join Date: Sep 2005
wow and i thought mine sucked
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
It sounds like your truck is possessed!!! Or maybe just mad at you for taking it away from the PO, you know kind of like a dog that poops on your brand new carpet right after you get it home.
-Scott- |
![]() Join Date: Aug 2005
I feel your pain! Did anybody go with you to look at the truck when you bought it?
Par for the course. You should see my old cruiser. I've killed the POs many times over in my head.
72 C2500 LWB 402 Sierra Grande 05 Odyssey 08 Tundra |
LAIDOUT
I feel for you man, the PO definitely worked to pull off a few "prop up" fixes to get the truck sold.
But I gotta ask, did you not see the driveline thing when you climbed under it to check the cab floor and mounts? |
Chief Honcho In Charge
You know...I have been there, done that and did not get the t-shirt. I chuckled as I read your rant cause I could have written it on a previous truck I owned.
I look at it this way. When I buy one of these beauties (and it is not beautiful when I buy it) I expect everything will need to be replaced. I am so relieved when something is not. I guess what I bought was a VIN with most of the parts...someplace to start. I am so relieved that so much is available...and I am so relieved there is a place like this to some to for a pat on the back and some info.
1992 1500 4x4 Shortbed 1984 Ford F250 Supercab Longbed 6.9L Diesel 1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C 1971 VW SuperBeetle 1960 Wife 1984 Son 1986 Son 1989 Son Previous Trucks 1967 C10 SWB (1980-1981) 1971 C10 LWB (1998-2004) |
Weekend Warrior
Take the 3-piece driveshaft and throw it through his front window (since he is only about 30miles away)
![]() They are all like that. I thought my truck was pretty decent and I checked it over good - when I cut the rockers off the truck the other day - the floor is not what it appeared to be ![]()
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() |
Junior Member
I just want to thank you. After reading your post, you have just turned my very bad day into a great day.
1972 GMC K2500, stepside, stock 350, 4 speed. Former F/D truck with 32,000 miles, no rust. 1973 Jeep CJ 5, 304, 33's with side pipes 2008 GMC 2500HD, CC, SWB, D/A, SLT |
It was a friday evening and a friend dropped me off on his way out of town.
The truck is soo low, when I looked under the truck it was out of view. The exhaust system with the Flows kind of hid it also. I could only see the rear part of the driveshaft. The cab mounts were good. ![]() The wife told me that I should just tear the truck down and start over. Of course I have to finish my '69 first. Thanx for the support. Dano
Man I laughed so hard I am crying!! I know this sucks, but if you didn't spin a wrench on it,it isn't "YOUR'S" Get it, I don't want to know what you paid for it, but I assure you when you are finished with the parts swapping, you'll have a nice driveable truck and a heck of a funny story to tell. I know it is not cool to derive pleasure from your pain but the bit about your wife looking at you like you're a perv becuase of the jimmeez!!
#13 |
typed ya a lil novel huh lol
#14 |
this is one reason why i dont like buying modified vehicles. you never know what the po was thinking.
67 c10 250 I6 3 on the tree no options air ride, paint and big block coming within the next 23 years 2001 mustang gt for going fast |
#15 |
I say this having been in your shoes, you should have gotten your friend to stick around and look over the truck at the same time you were. I missed a bunch of stuff when I bought my truck and I swore that the next time I bought a vehicle, I'd have a second pair of eyes there with me.
#16 |
![]() Join Date: May 2002
Man, I really do emphasize with you....been there, done that. I learned (the hard way) in 1968 that you can NEVER trust someone who spouses religion when you are striking a deal. Now, before anyone gets their panties in a wad, let me explain my feelings on this. I am NOT an atheist or anti-religion. However, I believe a man's religion is between himself and his Maker...and He is not impressed with those that use religion to further their cause, whatever that cause may be. Since 1968, when I was royally screwed by a "God-fearing" contractor, I walk away from ANY and ALL deals where the seller starts telling me what a religous person they are.........I have never been sorry.
They may be the most God-fearing person on the planet, I don't know. They have my admiration if it's true. But I also know it should NEVER be part of making a deal on a truck or anything else. I'm off my soapbox now..... ![]()
Stepsides look like real trucks! Smitty ![]() |
#17 |
Cereal Killer
dont know the latin....but buyer beware.
You made the deal. I bought my truck sight unseen from a board member through ebay.....more problems than he admitted but i have always accepted the consequences of my actions.
If I dont do it....somebody else will. |
#18 | |
Dude I feel your pain, but you sure made my week brighter. I am finally at a point where I have removed all traces of the PO
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 03-02-2007 at 07:22 PM. |
#19 |
King of Rust
I feel ya, I bought my 70 knowing very little about these trucks. The PO did a bunch of strange stuff, but like someone said earlier,,, its not yours till you turn some wrenches.
I think about the vehicles I've sold; someone cursed me too I'm sure! |
#20 |
chrome makes it go FASTER!
take some pix of the broken, jerry rigged, or plain broken parts. Then some day when your truck is show ready pull those pix out and say "good job,man"
Plus it may help to remember when you buy your next used vehicle
She can't cook and she won't clean. But she looks good in a skirt and she brings me beer. She can stay for now. EDIT:: But she left me anyway, So forget her. 1962 GMC Stepside V6 4 speed My rolling resto thread http://67-72chevytrucks.com/vboard/s...d.php?t=324226 My old farm truck http://67-72chevytrucks.com/vboard/s...=1#post3465005 |
#21 |
remember the guy who said he was burned out and frustrated with working on his truck? Pull out those pix and see how far you've come. Sometimes it's hard to remember that p.o.s. you bought when it's all shined up
#22 |
I feel your pain man, my firebird is the same way, the dude throw a cheap paint job on it and made it look pretty, but i never took the time to look under it ya the floors are shot, and this weekend im goin to help a friend get a 53 chevy truck from ebay and i will post pics when we get it
70 C10 SWB stepside forsale 00 Silverado Z71 Sold ![]() 95 Eagle Talon TSI turbo (Hellz ya its fast) 70 Chevelle 69 firebird 10 Silverado 4x4 |
#23 |
![]() Join Date: Feb 2001
Gee...
I thought Caveat emptor meant, "I'm going to emty your wallet"? ![]() When I bought my 70cst the guy said he would have no problems driving it 300 miles home. The first stop I made to get gas the battery went dead, and the starter was shot. ![]() ![]() I wasn't to happy then but as I look back what a hoot! ![]() Good luck with your truck. It's times like these when you start bonding with your truck. ![]()
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
#24 |
Saving 1 truck at a time!
Geez...that sounds like every POS I have ever bought! I guess I just expect it but don't ever spend more than $500 on a truck so no regrets...LOL! I know it will turn out right at the end of the day...especially after you throw that 3-piece drive shaft through his window...ROFLMAO!
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
#25 |
i feel your pain man, i want to kill any and all of my trucks POs exept for the guy i bought it from he got it in feb. and i got it from him in march and he put a in new dash pad, new glovebox insert, new brakes and axle bearings, new slave cylenders and a couple other things i believe but whoever had it before him was a jackass with the stereo install and theres a bunch of holes drilled in the bed for some reason which doesnt bother me and also they have a 69-70 grill and bumper on and its a 72 and they did a sh*ty job of it and not to mention the screwed up fender and part of grill and theres other things that i could talk about and show you in person on it but yea anyway i HATE POs atlest the bad ones anyway
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
