Old 08-30-2002, 08:39 PM   #1
MandarinSixSeven
Seasonal Poster
MandarinSixSeven's Avatar
Im scared...i think i broke it
I just finished installing my new carb and manifold set-up, got it all done, ready to go and, now it wont start, and of course its sitting in my driveway and i dont know what to do...
when i first turned it over it almost started, for about two seconds, then it died and now there is no sign of life, just cranks over for a long time and does nothing...i dont have any frickin' diagnostic tools either...so fack, who knows eh?
67 GMC Short Step
350/4-Speed/3.08 Posi
Front/Rear Sway Bars
Kelowna BC, Canada
Member of DTPW
MandarinSixSeven is offline   Reply With Quote
Old 08-30-2002, 08:49 PM   #2
Paul Clark
Got spark?
Got gas?
It should do "something".
Maybe (don't know what I'm talking about) the timing and the distributor is screwed up.
Paul Clark is offline   Reply With Quote
Old 08-30-2002, 08:57 PM   #3
MandarinSixSeven
Seasonal Poster
if the timing was way off, would it not start at all?
67 GMC Short Step
Kelowna BC, Canada
Member of DTPW
Old 08-30-2002, 09:01 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If the timing is way off, it wouldn't have "almost starte" at first.
Check the wires to your coil.
Old 08-30-2002, 09:03 PM   #5
flyin99
creator of kong
flyin99's Avatar
.........ummmmmmmm........major vacuum leaks???................soaked the plugs in gas maybe????............fuel pump has failed?..........just some theories......
flyin99 is offline   Reply With Quote
Old 08-30-2002, 09:24 PM   #6
racedvl
racedvl's Avatar
Is the distribtor 180 off?
racedvl is offline   Reply With Quote
Old 08-30-2002, 09:39 PM   #7
Hutch
Hutch's Avatar
Maybe try a little starting fluid sprayed over the carb.
It might not start but will help to eliminte other issues
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 08-30-2002, 09:41 PM   #8
Paul Clark
What little I know -
Pump the gas and see if it's squirting in the carb.
Pull a plug wire and ground it someplace to see if you have spark.
Dist. could be 180 off. - been there, done that.
Or (if it's a Holley carb) the power valve could be shot.
They won't start. Found that out once when it was 20+ degrees below zero.
Old 08-30-2002, 09:46 PM   #9
MandarinSixSeven
Seasonal Poster
i rotated the ditributor 180degrees since when i checked it, the mark that i made was 180 off! (dumb ass move), but that didnt help, but i noticed that on my old carb when you move the throttle you can hear air coming out of the jets, but not on the new one...possibly defective?...the fuel is getting to the carb, but not spraying out i think...cuz i unhooked the lines and gas spilled everywhere (including on my keyboard now ), and they were new lines too, so must mean gas is getting there...aaAAHHH!
i knew i shouldnt have bought a remanufactured carb....stupid stupid stupid
67 GMC Short Step
Kelowna BC, Canada
Member of DTPW
Old 08-30-2002, 09:47 PM   #10
MandarinSixSeven
Seasonal Poster
Paul no gas is squirting!!! damn!
is there an easy fix? or does it mean taking the damn thing apart?
67 GMC Short Step
Kelowna BC, Canada
Member of DTPW
Old 08-30-2002, 10:42 PM   #11
cacauba
STL-KKN
cacauba's Avatar
just a thought but check your oil and make sure there is no water in it. if the intake gasket didn't seal then you could be getting water where your trying to get fire.
chris
1969 C10 350/POWERGLIDE
1991 1500 EXTCAB 350
Formally: collegeK5er
cacauba is offline   Reply With Quote
Old 08-30-2002, 10:52 PM   #12
bigjimzlll
bigjimzlll's Avatar
dont freak..its probably something easy.. I would pour a little gas down the carb...just a little... and try starting..if it fires, then its your carb..its could be a stuck float or some crap plugging up the jets...tap on the float bowls(easily) I will sometime unscrew the idle adjustment screws and shoot some carb cleaner in the holes..just try to eliminate one thing at a time. If you have spark..and fuel.. it should run( timing could be a prob.) just check the easy stuff first
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 08-30-2002, 10:54 PM   #13
MandarinSixSeven
Seasonal Poster
well i checked the oil...and it smells like gas....so i musta flooded the ****e outta it....any suggestions? but that doesnt make much sense, there isnt gas squirting
oh well, i think im done for tonight, since i cant see anything its too dark....what do you do when you flood it like that?
man i feel like such a newbie!!! ive never done real engine work, anything else im fine with, but this is stressin' me out!!!
i wish i could have all you guys helping me at my house, then it would be running and we could do some racing Woo hoo!
you guys are all the best, im stilll open to any suggestions by the way tee hee
thanks guys
67 GMC Short Step
Kelowna BC, Canada
Member of DTPW
Old 08-30-2002, 11:01 PM   #14
MandarinSixSeven
Seasonal Poster
good thing i have some Chewin' tabackey stashed away, this is one of those times, where i will definately need it :P oh well, im gonna pull i plug wire first and check the spark first...
67 GMC Short Step
Kelowna BC, Canada
Member of DTPW
Old 08-30-2002, 11:05 PM   #15
bigjimzlll
bigjimzlll's Avatar
do you have a fire extingisher? with all that gas smell around..and sparks flying its a good idea..not to scare you..but an once of prevention........
Anderson,CA
Old 08-30-2002, 11:07 PM   #16
MandarinSixSeven
Seasonal Poster
yessir i thought of that dont worry haha
67 GMC Short Step
Kelowna BC, Canada
Member of DTPW
Old 08-31-2002, 12:59 AM   #17
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
if you think it's flooded bad, pull the plugs, spin it a few times, put the plugs back in and try it.......if still nothing, and you have no gas squirting from the accelerator pump, fill the float bowl through the vent, then try the acc. pump.....that should at least tell you if your pump is working.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 08-31-2002, 01:12 AM   #18
JoetheMobster
Listening since '86
JoetheMobster's Avatar
Bah! The funniest thing is dumping a bunch of gas down the carb and then firing up the engine! Nothing like flames shooting up outta the carb! Word of warning though, keep all clothes and hair out of the way!!!!! hahaha! Think your carb's a *****, take a look at mine. It looks like there's a friggin brake rotor on top of the opening of the carb. Has something to do with the CNG system installed. I don't have the first clue about working on CNG systems, so hopefully I don't have any problems in the near future!
2007 Saturn Aura - hey it WAS a GM product
JoetheMobster is offline   Reply With Quote
Old 08-31-2002, 08:46 AM   #19
RShaips
If you have gas in the oil you might have a bad fuel pump. Look at your oil closely to see if it is thin or runny looking. If you have spark and gas it should fire,unless your plugs are soaked in oil or gas. Good luck
RShaips is offline   Reply With Quote
Old 08-31-2002, 09:39 AM   #20
6869704X4
You need to change the oil if you have gas in it. Easy way to spin a bearing.
The more I learn about women, the more I love my truck.
6869704X4 is offline   Reply With Quote
