03-02-2007, 06:01 PM | #1 |
differental seal
My differental seal has gone bad on me and I need to replace it but I have never done it. So can anyone give me some details on the best way to accomplish this task. I know I need to remove my drive line, then the yolk. But whats the best way to do it.
Thanks JD |
03-02-2007, 06:47 PM | #2 |
Re: differental seal
Suggest you go here for info.......www.ring-pinion.com
Stepsides look like real trucks! Smitty |
03-02-2007, 06:56 PM | #3 |
I've done a few of those and it's pretty easy if you follow the manual.The hard part sometimes is getting the pinion bolt off if it's been put on by some gorilla,30 years ago. The instructions will say to hold the yoke in special tool xyz but that is if it's off the vehicle I believe. I just set the e-brake and put a pipe over a non-Chinese breaker-bar or if I'm lucky enough to have access to a compressor and impact air-wrench,no problem.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
