Old 03-02-2007, 11:10 PM   #1
cstm68
cstm68's Avatar
sway bar braket?
i pulled a sway bar off of my parts truck and i am buying all new bushings for it. do i need to grind the braket off the parts truck frame that brings the sway bar down about 3 inches or can i just bolt it to the frame???
cstm68 is offline   Reply With Quote
Old 03-02-2007, 11:18 PM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Re: sway bar braket?
I think you have to use the bracket to install it, but I'm not 100%. You can buy a bracket for lowered trucks that doesn't hang as low as factory. Hope this helps.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 03-03-2007, 12:19 AM   #3
Frizzle Fry
Frizzle Fry's Avatar
I didn't use brackets. No issues:
Frizzle Fry is offline   Reply With Quote
Old 03-03-2007, 01:07 AM   #4
Bob Moore
Fizzle - that looks like a BIG bar - 1 1/4"?
68 You can do it that way. You can do it with brackets. ECE also makes brackets for lowered trucks - it winds up inbetween the stock bracket and no bracket. Check out their online catalog.
The 1 1/4" bar is available on C30's and crew cabs. I'm not sure how much more anti sway you get but it is like 3 times the 1/2T bar.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 03-03-2007, 01:29 PM   #5
Frizzle Fry
Yes it's a 1 1/4" bar. I HIGHLY recommend it. I went from a 1 1/8 with stock bushings to the 1 1/4 with poly bushings and it made a huge difference! The 1/14 bars are also on the 73-87 3/4ton and up trucks.
Old 03-03-2007, 01:45 PM   #6
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I have one of each Diameter, both useless, My truck is Bagged, anyways
pretty much what everyone has said above is correct, either way works.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 03-03-2007, 01:45 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I did an FAQ article on the front swaybar with different options for mounting and such. It's in the FAQ if you want to read it.
Old 03-03-2007, 02:01 PM   #8
ChevyDude
I didn't know you could do that??? I got my lowered brackets from ECE.
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 03-03-2007, 04:18 PM   #9
Frizzle Fry
What do you mean useless?
Old 03-03-2007, 07:17 PM   #10
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
My front travels up and down 7" and I still can go another 1"
Will the ends of the bar stay in the lower control arms? I've
been told they will not, alas I have not actually tried it yet.
Old 03-03-2007, 08:12 PM   #11
Frizzle Fry
I see what you're saying. I've always heard that having bags gives you more of a need for a sway bar. But I don't know about the travel limitations.
Old 03-03-2007, 08:44 PM   #12
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Mike,
Yeppers, that's what I don't know either, I would rather use a stock type
if it would work, mainly because the aftermarket stuff ain't very cheap
Craig
