03-03-2007, 03:14 AM | #1 |
Pulley bolts to balancer
How long are the bolts that hold the pulleys onto the balancer? I lost mine and need to go get more.
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
03-03-2007, 10:53 AM | #2 |
Re: Pulley bolts to balancer
they are 1 inch long and usually fine thread 3/8
03-03-2007, 02:09 PM | #3 |
I got 1 1/2 inch. Thats ok I need to head to the hardware store to get a few things anyway. Does it matter if they are grade 5 or grade 8?
03-03-2007, 02:21 PM | #4 |
I'd use grade 8 myself but 5's should be fine. I'm not sure what they are from the factory.
Also, if you're running a short water pump and have one of those cast bottom pulleys you might need a little longer bolts. Maybe 1-1/4 in or so. They can be a little to long as long as they don't come in contact with the timing cover when ya tighten 'em up.
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
