Old 03-03-2007, 03:51 AM   #1
alex19
NEED HELP! leaky tranny cooler lines
Hi guys, I really need help. My truck is leaking a HUGE amount of ATF out of where the cooler line threads into the tranny. Is the cooler really needed all the time? Could I Remove the lines and thread a stopper bolt in there while i try to find new lines? Do they have to be the hardline style or can I get barbed fittings to put in there and then use rubber hoses and clamps? I need to know how to fix this quick and any help would be GREATLY appreciated.
Alex
alex19 is offline   Reply With Quote
Old 03-03-2007, 04:12 AM   #2
blaserman
blaserman's Avatar
Re: NEED HELP! leaky tranny cooler lines
If I remember right the cooling lines are not under a lot of pressure, so you could jusr get a new fitting and hard rubber line and it should work. Just not real sure about the pressure part. Getting old can't remember **** anymore.
This is my best friend
blaserman is offline   Reply With Quote
Old 03-03-2007, 05:24 AM   #3
rcbildr
rcbildr's Avatar
I used rubber hoses on a 71 Chevy I had and they worked great. I've heard somewhere not to use fuel line...something like, it will not last long. maybe someone else can verify that.
Back when my Suburban had an automatic, I made up some hydraulic lines for it. I went to a place that specializes in hydraulic fittings and showed them the type I needed and then cut the hose, and crimped on the fittings at work.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 03-03-2007, 09:34 AM   #4
Restrorob
The One And Only !!!
Restrorob's Avatar
I went to the local parts store and bought a straight replacement brake line and a $5.00 tubing bender and copied the bends from the old one......
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
