Old 03-03-2007, 03:10 PM   #1
Blizz
Blizz's Avatar
can someone tell me how to take rocker pans off?
as detailed as possible please
'72 K5 CST Blazer 4x4 in perpetual progress
'96 2dr Tahoe 4x4 daily driver, Black Bear Performance tune, 285-75-16 Nitto Grapplers, Magnaflow muffler, K&N Air filter, Bilstein Shocks.........E-fan, DT Tri Y or Pacesetter LTs coming soon
Blizz is offline   Reply With Quote
Old 03-03-2007, 03:12 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: can someone tell me how to take rocker pans off?
Do you mean the rocker panels (rounded sheet metal under the door) or the rocker boxes (Flat metal under the body of the truck between the rocker panels and the frame)?
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 03-03-2007, 03:42 PM   #3
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
What Bouncy said, 1st one will be the easier of the two, both require some
skills as far as removal and replacement, have you tried using the search?
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 03-03-2007, 04:26 PM   #4
vtblazer
vtblazer's Avatar
Find and either grind off or drill out the spot welds holding the parts on.
Look in your (you either have one of should get one) factory service manual, all spot weld locations are pretty well laid out in there.
They make a 'spot weld removing' tool but I've never had great luck using them.
vtblazer is offline   Reply With Quote
Old 03-03-2007, 04:32 PM   #5
vtblazer
vtblazer's Avatar
*Outer rocker will be both bolted and welded in place.
*Inner rocker, same.
*Torsion box, which contains the torsion rod (hence the name) has a removable rear panel and the rest is welded in place.
As always...find a way to keep both the front and rear door pillars from moving while your replacing any or all of these parts.
Old 03-03-2007, 05:32 PM   #6
69TowRig
Look here:
http://67-72chevytrucks.com/vboard/s...el+replacement
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 03-03-2007, 07:07 PM   #7
jaros44sr
jaros44sr's Avatar
Good thread, towrig, lots of useable info there!!!!
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 03-04-2007, 12:02 AM   #8
JUSBLAZ
JUSBLAZ's Avatar
Does anyone know why these all go bad? I mean... you can take the cleanest blazer out there and still find that it need new rockers.
just curious
JUSBLAZ is offline   Reply With Quote
Old 03-04-2007, 08:28 AM   #9
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
The biggest issue I know about them is they hold water
