Old 03-03-2007, 04:53 PM   #1
paul5663
paul5663's Avatar
New-B needs advice on C4 susp.
Hello all,
I'm a new guy to this site and thought it may be the place to gain some much-needed advice on installing a complete C4 suspension into my 58 Chevy Apache project.
The plan is to use Flat-Outs front crossmember kit along with the bolt-on rear kit. Motor will be 454 BB from an 86 Silverado along w/ TH400 tranny from the same truck.
I guess I am seeking any and all information I can acquire regarding this setup. Anyone w/ experience installing a big block into a 55-59 chevy pickup will be a huge help to me as well.
Here are a couple of pics to show what I am starting with, a pretty solid roller. Thanks much!
paul5663
paul5663 is offline   Reply With Quote
Old 03-03-2007, 06:15 PM   #2
58 gmc
ToTM Winner
58 gmc's Avatar
Re: New-B needs advice on C4 susp.
Good Lookin 4 holer, keep us updated on your progress.
58 gmc is offline   Reply With Quote
Old 03-04-2007, 10:24 PM   #3
CAL 58 GMC
CAL 58 GMC's Avatar
Welcome to the board from Central Califorina!
CAL 58 GMC is offline   Reply With Quote
Old 03-04-2007, 10:36 PM   #4
Igotachevyor2
Apache Club
Igotachevyor2's Avatar
nice project
58 CHEVY APACHE I 74 CHEVY C-10 I 78 K-10 donor truck I 89 SONOMA
My Trucks Apache Sitting Idle MySpace
Project Dad's Truck (74 C-10 to K-10 conversion)
Igotachevyor2 is offline   Reply With Quote
Old 03-05-2007, 11:21 AM   #5
poncho_villa
poncho_villa's Avatar
Check out this thread;
http://67-72chevytrucks.com/vboard/s...ighlight=block
You probably will hafta massage the firewall for clearance and maybe you want to shave that anyways. Good luck on such a sweet project and keep those pics coming.
poncho_villa is offline   Reply With Quote
Old 03-06-2007, 12:02 PM   #6
fuchster
fuchster's Avatar
Hello:
I am using Flat Out parts. Check out my CarDomin site. PM me for more.
http://www.cardomain.com/ride/2330005
fuchster is offline   Reply With Quote
Old 03-06-2007, 12:23 PM   #7
Kabwe
Certified Car Nut
Kabwe's Avatar
Fuchster I was just about to send him to your cardomain site.
Kabwe is offline   Reply With Quote
Old 03-09-2007, 06:45 PM   #8
paul5663
paul5663's Avatar
Thanks a mil. Where are you now on your 58?
Old 03-09-2007, 07:17 PM   #9
Kabwe
Certified Car Nut
Kabwe's Avatar
If this was directed to me I at the point of no return, too much money spent and it still looks like crap, but I'm in too deep to stop now.
Really I'm at the mock up stage almost really for my 2nd tear down and reassembly starting from the frame up.
Old 03-09-2007, 07:27 PM   #10
Jebb1978
Jebb1978's Avatar
I suggest sending Frizzle Fry a PM. He is doing a 60-66 with a C5 (I think) set up. Find his thread in the 60-66 forum and check out the pics. The work is amazing to say the least.
Good luck on it, it looks like a solid start.
Welcome!
1959 GMC project
Jebb1978 is offline   Reply With Quote
Old 03-09-2007, 07:31 PM   #11
Jebb1978
Jebb1978's Avatar
Thumbs up Re: New-B needs advice on C4 susp.
Here it is, found it.
http://67-72chevytrucks.com/vboard/s...d.php?t=179289
1959 GMC project
Old 03-09-2007, 09:48 PM   #12
paul5663
paul5663's Avatar
Thanks Jebb, the Frizzle 61 C10 / C5 is seriously impressive and definitely is inspiring me to get the 58 C4 officially started. Good news is the complete '85'vette suspension is on it's way from Michigan. I run a powder coating business so everythings getting a new finish. Flat out install kits for front and rear are ordered. I'll post detailed pics of powder coat process and build as it progresses. Got the fever.
paul5663
Old 03-10-2007, 04:14 PM   #13
Jebb1978
Jebb1978's Avatar
Awsome! Can't wait to see what this one will turn out like!
Fuchster that truck is gonna be NUTS! Nice work!
1959 GMC project
Old 03-31-2007, 01:51 PM   #14
paul5663
paul5663's Avatar
Some recent developments: Suspension is in and work has officially begun. Recieved the FlatOut rear install kit and the parts appear to be of decent quality. Powder coated all four calipers. and will be posting more soon of A-arms and hubs and more to be coated.
I ordered an "X-member" from Progressive Automotive to stiffen the frame. Hasn't arrived yet. Anyone used one of these before?
Old 08-08-2007, 09:59 PM   #15
paul5663
paul5663's Avatar
Apache - C4 install update
It's been a while but have made some progress since last post. Got down to business on the frame and front and rear are both in place. Now to box entire frame and install Progressive Automotives X-member. Picked up some 18" Coy C5 wheels that should look fine. Mocked up what I could to get and idea on the stance. I'll add more as it goes down.
Old 08-09-2007, 12:37 AM   #16
MrSinister
MrSinister's Avatar
great stance even without the heavy stuff in it
'56 Big window
350/700r4
9" rear w/disc
MrSinister is offline   Reply With Quote
Old 08-11-2007, 01:44 AM   #17
nuke1
nuke1's Avatar
that is gonna be sinsiter looking.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 10-14-2007, 03:46 PM   #18
paul5663
paul5663's Avatar
Latest on my 59....... have frame boxed and progessive X-member is in place. Next will be to place cab on frame to line up position of brake pedal bracket etc, as well as mock-up motor (opted for ZZ4) and trans (700R4) to position motor and trans mounts.
Old 10-14-2007, 04:21 PM   #19
Coronas56
Coronas56's Avatar
Did you center your wheels in the front fender?
Coronas56 is offline   Reply With Quote
Old 10-14-2007, 04:36 PM   #20
paul5663
paul5663's Avatar
I installed the crossmember onto the frame as directed by Flat Out's directions included with the kit. I mocked up the frontend and it was well centered (see pic)
Old 10-14-2007, 09:48 PM   #21
chevyrestoguy
chevyrestoguy's Avatar
I love it! Keep postin' them pics! Very nice fab work, by the way.
chevyrestoguy is offline   Reply With Quote
Old 10-14-2007, 09:49 PM   #22
entourageguy
Yellow truck club
entourageguy's Avatar
This is starting to look killer......
Keep the pictures coming..
Always like seeing another 4 lighter come back to life ....
Brian ....
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 10-14-2007, 09:57 PM   #23
pgf545
pgf545's Avatar
Paul, looks great. I am going to be installing the Progressive cross member soon....probably next weekend or the one after. Did you have any issues with it? From the looks of the directions it looks pretty straight forward. Keep up the great work.
Bernie
52 Chevy Truck (Dad's)
http://67-72chevytrucks.com/vboard/s...d.php?t=206021
pgf545 is offline   Reply With Quote
Old 10-14-2007, 09:57 PM   #24
entourageguy
Yellow truck club
Any one have the link for Flat-out ??
Brian ....
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 10-15-2007, 06:17 PM   #25
paul5663
paul5663's Avatar
Thanks Bernie and no, not any real problems w/ installation. Just square and measure often. Went pretty smooth, I'm not gonna win any pretty-weld beauty contest... thats for sure, but it'll hold.
Brian, unfortunately Flat Out is only reachable by phone (714-639-2623). Good part is that Don is very knowledgable and will certainly take care of his customers, at least that is my experience so far.
