Old 03-03-2007, 04:55 PM   #1
MXmaniac
MXmaniac's Avatar
C-20 rear axle removal
I am putting new wheel cylinders and brake lines in my truck but the axles must come out to get inside the brakes. What exactly do I have to do to take the axles out? Any suggestions or tips?
Thanks in advance
Andrew
'69 C-20(292, 4-speed) Retired Daily Driver
'64 C-10(250, 3-speed) Fixerupper
'97 F*rd Mustang GT(4.6L, 5-speed) Daily Driver
If I only wanted two pedals I'd have bought a bicycle.
MXmaniac is offline   Reply With Quote
Old 03-03-2007, 05:50 PM   #2
GMCBubba
GMCBubba's Avatar
Re: C-20 rear axle removal
maniac, i just did all that brake work on my gmc and did not have to take out the axles. not sure if mine is different...
1969 GMC 3/4 ton, 307, 4-speed NP435GL, DANA 60, 4.10, HD rear leafs, manual everything, leaking oil and water. Now rocking 383, NV4500, power steering, power brakes. Finally undergoing restoration.
GMCBubba is offline   Reply With Quote
Old 03-04-2007, 06:49 PM   #3
TONE
TONE's Avatar
JUST DID THIS LAST WEEKEND, AND I DID HAVE TO PULL THE AXELS ON MINE. JACK IT UP AND PULL OFF THE WHEEL. YOU WILL SEE SIX OR EIGHT AXEL BOLTS THERE. PLACE AN OIL PAN BELOW THE BOLTS TO CATCH THE OIL THAT WILL BE RUNNING OUT. REMOVE THE BOLTS AND SLIDE THE AXEL OUT. SPRAY BRAKE CLEANER AROUND THE AXEL BEARING SO YOU CAN SEE BETTER. INSIDE THE HOLE YOU JUST REMOVED THE AXEL FROM, YOU WILL SEE A "STAR" NUT. BEHIND THAT THERE IS A FLANGE WITH TABS ON IT. ONE OF THE TABS IS BENT DOWN INTO THE STAR NUT. WITH A SCREW DRIVER PRY THE TAB UP AND OUT OF THE NUT. THEN TAKE YOUR SCREW DRIVER ALONG WITH A HAMMER AND TAP THE STAR NUT COUNTER CLOCKWISE. THEN IT WILL TURN PRETTY EASY SO THEN JUST TURN WITH YOUR SCREW DRIVER. FIRST WILL COME THE NUT, THEN THE FLAGE WITH THE TABS ON IT, THEN A LARGE WASHER. KEEP EVERYTHING IN ORDER. AFTER THAT IT WILL ALL COME OFF EASILY. AS FOR THE WHEEL CYLINDERS, THERE ARE TWO BOLTS HOLDING IT IN. ONE IS EASY TO GET TO. IT COMES OUT. THE OTHER IS HARD TO GET TO. IT DOES NOT COME OUT. IT HAS BEEN SLID DOWN INTO A SLOT. JUST TAKE A PRY BAR OR A PRY BAR AND HAMMER, AND PRY IT UPWARD. IT WILL COME OUT WITH A BIT OF ENCOURAGEMENT. THEN JUST REVERSE ORDER PUTTING THINGS BACK TOGETHER, JUST DON'T FORGET TO BEND THAT TAB BACK DOWN OR YOUR WHEEL MIGHT END UP ON SOMEBODY ELSES CAR! HOPE THIS HELPS! IT'S NOT TOO HARD ONCE YOU FIGURE IT ALL OUT. SIDE 2 WILL BE MUCH EASIER THAN SIDE 1! GOOD LUCK
67 C 20 BOWTIE (IN PROGRESS)
- 1972 350 ENGINE
- MUNCIE SM 420
- 4.56 GEARS
TONE is offline   Reply With Quote
Old 03-04-2007, 07:17 PM   #4
WorkinLonghorn
WorkinLonghorn's Avatar
Not trying to be a wise A## but you really should consider getting the manual. It will make everything MUCH easier!
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 03-04-2007, 07:37 PM   #5
va_tlc
va_tlc's Avatar
tone is exactly right i just got home from my bro"s shop , and thats what we have been doing front and rear brakes on the c/20, i had to call a friend on the how toos also, only if i would have asked b4 i went to work on it huh, but like tone stated pretty easy after ya tear into it, the store ordered me the wrong wheel cyl for the front, the hole in it was to small for my brake line fittin to screw into, hopefully the right ones will be here in the moring,hey workinglong horn where do i get a manual and does it have all this in the book? that would def be worth having thanks
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
va_tlc is offline   Reply With Quote
Old 03-04-2007, 08:50 PM   #6
No3Fan4Ever
Running on empty
No3Fan4Ever's Avatar
try this link.............great pictures
http://www.lighthouse57.com/brakes.htm
hope this will help
We have two rules here at the Rock.
Rule #1: No writing on the walls.
Rule#2: Obey all rules
70 GMC Sierra Grande "Custom Camper" Longhorn 402 Big Block TH400 PS PB factory AC Posi;
94 Bronco XLT 302, auto;worn out daily driver
No3Fan4Ever is offline   Reply With Quote
Old 03-04-2007, 09:00 PM   #7
msgross
msgross's Avatar
hope this will help
that guy wants $10 to view the info...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 03-04-2007, 10:09 PM   #8
MXmaniac
MXmaniac's Avatar
Thanks guys. I ended up going out and pulling the axles right after I made this thread. I just walked out there and thought, "I bet all I have to do is take those bolts out..."
Andrew
Old 03-05-2007, 12:11 AM   #9
rage'nrat638
rage'nrat638's Avatar
yup question is did you have too?
rage'nrat638 is offline   Reply With Quote
Old 03-05-2007, 12:47 AM   #10
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
never did say if it was a eaton or a d60, i thought the d60's had the slide off drums.
trkklr77 is offline   Reply With Quote
Old 03-05-2007, 07:39 AM   #11
No3Fan4Ever
Running on empty
Sorry..........he had posted the info some time ago; used to be free
Old 03-05-2007, 08:46 AM   #12
brak
brak's Avatar
personally i like the Haynes manuals, because they have lots of pictures...
Cost $14 at your local parts store.
It's the first thing i buy when i get a new vehicle. I must have 15 different manuals now.
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
