Old 03-04-2007, 12:48 AM   #1
six4flat
six4flat's Avatar
header question
my truck is a 64 with a 350 and wanted to know if these will fit without any problems they are Heddman headers
six4flat is offline   Reply With Quote
Old 03-05-2007, 08:30 PM   #2
mbgmike
Re: header question
The recommended headers from hedman is part number 69640 for that style.
here is a pic
looks like the number one plug may have trouble installing to me
mbgmike is offline   Reply With Quote
Old 03-05-2007, 08:36 PM   #3
six4flat
six4flat's Avatar
Re: header question
ok thanks
Old 03-05-2007, 09:44 PM   #4
wild one
Registered.........
wild one's Avatar
Re: header question
Not trying to:tj:,my neighbor purchased a set of headman 3/4 length headers for his truck (1965 350, floor shift 4 speed) installed them and loved them. Only problem is he sold the truck recently and doesn't have any info as to the headers part number. Any ideas?
1966 C10 panel-400 small block/TH 350 combo
Nothing is fool proof to a talented fool!
Popcorn:
Pops at exactly 444 degreese
Expands to 44 times it's original size
Has a 4 year shelf life
wild one is offline   Reply With Quote
Old 03-06-2007, 09:33 PM   #5
NF65Fleetside
NF65Fleetside's Avatar
Re: header question
Yah I kinda have the same question, Ive got a 65' and doing a 350/350 swap this weekend but wanting to put some headers on it, just wondering what would be a good set to order from Summit so I can get them in by Sat.
NF65Fleetside is offline   Reply With Quote
Old 03-15-2007, 11:51 PM   #6
wild one
Registered.........
wild one's Avatar
Re: header question
Anyone?
Popcorn:
Old 03-16-2007, 12:24 AM   #7
Captainfab
60-66 Nut
Re: header question
If you can use a full length header, I've used ones for the 73-87 trucks. The only problem with using these is if you have a manual tranny. You have to rework the clutch belcrank to make them work. The Hedman numbers for these are 69090,69092,69097,69099. They are basically the same except for the port style. I've not used these hedman's on a 63-66 but they should work, except for like I said about the belcrank.
Old 04-14-2007, 01:39 AM   #8
protrash64
Resistance is Futile
protrash64's Avatar
Re: header question
For anybody still on this topic, I bought generic Summit headers for an 88-95 small blockwithout air injection; (I think, its been awhile). they fit very well; sort of a mid length type header.........I welded up the oxygen fitting in the drvr side and took off a little frame for clearance right at the collector.....maybe 1/4 inch max.....BUT, I have my engine mounted on the FRONT set of holes for more clearance at the firewall. Probably no issues with the back position but I see most people on the site still have their engine in the stock location........good luck........
by the way, the Summit headers were Pacesetters..........
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 04-18-2007, 01:31 PM   #9
sneezys72
Re: header question
Protrash, do you have pics?
sneezys72 is offline   Reply With Quote
