Mechanical secondaires
What is the advantage of running mech as apposed to vacuum secondaries? Never had mech people tell me I should try it.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
![]() Join Date: Dec 2006
Re: Mechanical secondaires
I heard they are good for racing,gives you more control. I'm sure some will comment.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
they're better for more aggressive cams where the gas is dumped in relation to your foot/vaccumes secondaries have a bit of lag for the engine to catchup b-4 dumping the fuel in so that the engine doesnt flood
vac secondaries on a street truck and about anything heavy at that. mech secondaries usually when your doing mostly strip or racing.vac secondaries will stay closed more and yield somewhat better mileage as opposed to a mech secondary carb where it just wants to empty the tank in a hurry
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
I've got 650DP on my 355/ Weiand Xcelerator/ 10.3:1/ hedman torq step headers full 2.5" and it works GREAT. Sea level to 7K'. Worked fine when engine w/ 8.8:1, also. BTW it's a daily driver. Mileage was the same w/ 750 vac. sec. Throttle response is better fer sure. DP's offer more tunability.
Though you can replace the secondary fuel plate w/ metering block w/jets on vac sec., it helps. Got a 750 like this on my Burban's 400. If it's tuned right, DP's work better. Especially if you like to get on it, cuz I sure do ![]() ![]() Opinions may vary. ![]() |
As I see and understand it, and as the Holley Website explains it, the mech secondary/double pumper carb works best for engines that rev up quickly (e.g. light cars, stick shifts, low (numerically) rear end ratios). Vacuum secondaries carbs are usually (but not always) better for the other 90% of us. The back 2 barrels of a vac secondary carb opens only when the engine's airflow has come up enough to demand it. Both types usually require some decent tuning to get optimal performance.
I had a Mech secondary 750 CFM Holley on my 454 "El Camona" that has 3.55 gears and a TH700 tanny. Nailing the gas from a stop would cause it to pop back through the carb and stall briefly due to getting too much air and leaning out. Swapping to a vac secondary Holley carb fixed the problem instantly. I've learned since then that I could have increased the accel pumps and the squirters on the mech secondary carb and that probably would have eliminated the bog, but I'm still very happy with the vac secondary carb's performance.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe |
Problem Child
![]() Join Date: Sep 2005
I'm not sure but aren't edelbrock carbs mech secondarys.
1972 gmc sierra grande 350/350 a/c soon`to get a new 350 ![]() ![]() ![]() |
#8 | ||
Not much point in a hi performance carb on lo performance engine, eh. ![]() Quote:
Are you sure it was leaning out? Cuz generally lean will cuz it to lay flat on it face then go. Maybe timing, too? Last edited by Schralper; 03-04-2007 at 09:59 PM. |
Parts and more parts
There will be comments that the mechanical secondaries are NOT for a street truck. That is a choice for each person. I am running an Edelbrock AFB design carb on my truck and also on my Son's truck, with no issues with the fact that they are mechanical. What is noticed the most in this type of carb is the changeover to the secondaries being a large surge on a mechanical vice a vacuum carb. That is if you don't adjust the carb to be moderated in it's functions. My 383 stroker (agressive cam) responds well to the mechanical secondaries and my Son's 350 (slightly agressive cam) works just as well, so it is not a problem to us. I have run vacuum secondaries and would agree that the transition is smoother, but it is just what you are used to.
I've never seen one that is. But let me clarify though what I mean by vacuum secondary.
All the Edelbrock carbs I've ever seen have a vacuum controlled air horn (air valve) atop the mechanically opened secondaries. While the back barrels (down on the throttle plate) might indeed open mechanically, the air doesn't start flowing until the top plate opens. And that only happens when the engine CFM (demand) increases and the vacuum level starts to increase. This prevents the leanout "bog" that's typical with carbs that have no acellerator pump for the secondaries. Also, it operates (functions) just like a Holley which uses vacuum to physically open the secondaries. That's what I meant by vacuum secondaries on an Edelbrock. Edelbrocks are kind of a hybrid carb similar in function and design to a Thermoquad or a Quadrajet. The advantages of a vac secondary carb are you don't squirt a 35CC shot of gas every time you open the back 2 barrels. Plus, the engine vacuum never goes to zero even if you stomp it. So there's rarely if ever any "bog" when flooring it, even from an idle with a heavy vehicle and a long 1st gear. The main disadvantage of a vacuum secondary carb is because it isn't squirting in the extra gas when the engine needs it most, it's a lower performance alternative that's better adapted for 90% of us that do mostly normal or street driving. Will performance be better with a well tuned double pumper/mech secondary carb? Absolutely (but some will argue). Will economy and driveability be better with a well tuned Edelbrock or Holley or similar vacuum secondary carb? Absolutely. 'Guess it all boils down to your needs and wants. Hope that helps.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe Last edited by mnunn454; 03-05-2007 at 07:32 PM. |
#11 | |
However, there comes a time and an aggravation level for each of us when our "limit" is reached. I had been into the DP on 3 different occasions and spent $75 on various parts and gaskets and hadn't yet solved the problem. I had reached my "limit". So, like you have on various occasions, I threw down the 4 plastic numbers with an expiration date and viola', the problem disappeared. I don't regret it. After I cooled off a little, I pulled the DP carb apart for a 4th time and threw in larger squirters, larger acellerator pumps adjusted all the springs and rebuilt it again. I now have it on my C-10 and she screams. ![]() However, though I love the performance, my vac secondary Elky gets two to four (20-40%) more MPG than the mech secondary truck does ![]() There's always a price to be paid for performance.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe Last edited by mnunn454; 03-05-2007 at 07:29 PM. |
Some fuel for this fire
http://www.classictrucks.com/tech/cl...ng_carburetor/ "my vac secondary Elky gets two to four (20-40%) more MPG than the mech secondary truck does" BUT from the looks of your sig, the elky's got OD? and truck doesn't? |
