Old 03-04-2007, 05:53 PM   #1
76bonanza
76bonanza's Avatar
autometer cluster Wiring
I am wiring my new autometer gauges and have a few questions. First what guage wire should I use. And with all the grounds and guage light wires How is the best way to collect them into one feed wire? (some kind of distrubution block or just thee pigtails?)
Thanks for any tips I will be using a Pin connector plug for all the senders and stuff.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 03-04-2007, 08:43 PM   #2
Southedisto
River life......
Southedisto's Avatar
Re: autometer cluster Wiring
Painless has a great harness, almost plug and play.
HERE IT IS
Southedisto is offline   Reply With Quote
Old 03-04-2007, 09:51 PM   #3
76bonanza
76bonanza's Avatar
I like the harness but wow 75.00 bucks most of my guages are mech also so really just need to wire the lights and grounds and like 3 signal wires.
1968 c10
lowered 3" 4"
Old 03-05-2007, 12:29 AM   #4
Southedisto
River life......
I would just make one then, they arent complicated by any means.
Old 03-05-2007, 01:15 AM   #5
metalmassfab
Junior Member
metalmassfab's Avatar
I built a gauge panel, and spent mega bucks on those autometer ultra lites a few years ago. I used 14 ga. wire coming off each gauge, and pigtailed the grounds and lights in groups of three as you mentioned. I used a double male, single female connector to connect the sets of three together, and ran a single 12 ga. common ground and another to the headlight switch for the lights. the tach and speedo lights were wired together in the same manner (8 gauges total) Next time I do a gauge panel, I'll use 16 ga. wire and maybe weather-pack type multi connectors, or do a nice soldered harness. Anyway, hope it helps a bit...cant seem to find any pics of the wiring, I'll keep looking.
Ryan
Metal Massacre Fabrication
New Projects:
-New radiator core supports, steel and stainless
-Aluminum radiators
-Aluminum dual electric fan shrouds
'69 C-20 Custom
'69 Nova...BIG BBC soon
'72 3-door 'Burb...in a few
'94 K2500 454 'Burb
metalmassfab is offline   Reply With Quote
Old 03-05-2007, 03:36 AM   #6
FLEET72
FLEET72's Avatar
Originally Posted by metalmassfab View Post
<snip> Next time I do a gauge panel, I'll use 16 ga. wire and maybe weather-pack type multi connectors, or do a nice soldered harness. Anyway, hope it helps a bit...cant seem to find any pics of the wiring, I'll keep looking.
8 gauges (lights only) 4 watts ea. = 32 watts / 12 volts = 2.6 Amps.
Ampacity of 14 ga. wire is 32 amps. at 60c .... 18 ga. is plenty for instrument lights capable of handling 16 Amps.
Source: xtronics.com wire gauge ampacity chart
This isn't a truck but demonstrates the proper use of zip ties.
Oscar
'72 Shortbed Fleetside
'95 Jimmy 4X4
'69 GMC Custom Camper
FLEET72 is offline   Reply With Quote
Old 03-05-2007, 03:09 PM   #7
metalmassfab
Junior Member
Excellent! smaller wire the better, thanks for the info!
Ryan
New Projects:
-Aluminum radiators
'69 C-20 Custom
'94 K2500 454 'Burb
Old 03-05-2007, 03:30 PM   #8
Rollie396
someday it will be done!
Rollie396's Avatar
That is how I want my harness to look when I'm done (well not exactly cuz that ain't no truck)!Very clean.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 03-05-2007, 11:31 PM   #9
FLEET72
FLEET72's Avatar
Take your time, lay them out long, label and then trim them 1 at a time as you put on the terminals. Allow for service loops.
Oscar
'95 Jimmy 4X4
Old 03-06-2007, 12:02 AM   #10
Rollie396
Rollie396's Avatar
You forgot to mention all the swearing,mysterious anomalies and thoughts like "why did I ever start into this".
'80 LWB 2wd beater
my pics
