My sons 70 C-10 has some Edelbrock valve covers that I guess are baffled on a 350 sbc v8. It takes 5-7 minutes to pour 1 quart of oil into the heads through the breather port without the oil overflowing. If my memory serves me correctly, my dad's 65 Chevy shortbed fleetside had I think a 1969 350 sbc with an oil filler cap on one of the valve covers...not a breather hole but just sort of a flat metal cap that would lock down when turned clockwise. Does Chevy or an aftermarket vendor make a valve cover with a capped oil filler hole in addition to the breather hole?
Thanks. |
Re: SB Chevy Valve Covers
look down in the grommet. When they come new, the bottoms arent cut out. Maybe the PO only cut a tiny hole in the grommet. That or someone may have put a baffle inside the cover.
WELCOME TO THE BOARD
Parts and more parts
Does the valve cover ONLY have a rubber grommet/baffle in the hole or after you pull the breather, can you see a metal piece inside? If it is metal, then you can take the valve cover loose and open that piece up a little and the oil runs down better. If it is the rubber grommet/baffle, then it can be opened more to allow oil addition. I have been using aftermarket valve covers and adding oil through the holes for the breather for years, there is always a way to make it better.
Spanked once
![]() Join Date: Oct 2006
There is a metal plate just below the grommet...I presume this is the baffle. Both valves covers are the same. And it doesn't matter if I remove the rubber grommet or not..the oil can't be forced into the head any faster. I'm still hoping someone can confirm or refute my recollection of a stock GM valve cover that had two holes...with one of the holes having a twist on/off metal cap for the oil fill hole. If there was such a valve cover I would like to get my hands on a set. BTW...I will see if I can modify the current baffle in the existing cover to get better throughput. Thanks for all the help.
Insert Title Here
mine have the twist off metal cap... they are Goodwrench parts
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
You can go and buy a GM valve cover, and use them because they have more than one hole OR you can take the ones you have off and take a drill and open up some flow holes for the oil. I would look at how much room there is betweent the plates and the metal of the cover, there is undoubtedly a restriction. I personally would go for the revamp of the Edelbrock covers, but it is your choice.
On my covers, that I put my oil in throguh the same openings as the breather sits in, I have metal type baffles on them and I do not have to wait very long to get oil into the motor. It is a little slower than using an open hole, such as one with a fill cap, but it is quicker than what you stated in your query. Last edited by piecesparts; 03-05-2007 at 12:02 AM. |
Here you go... http://www.jegs.com/webapp/wcs/store...56593_-1_11355
If you want to keep the edelbrock valve covers, just remove the baffle and buy a push-in oil fill cap. This is the route I went when I lost one of my baffle studs. |
Thanks all...I think 1LoC10's pic of the Goodwrench valve cover is what I was thinking about...I really appreciate all the other info and the web link from AO50...Also...piecesparts, nice motor...you've got way deeper pockets than I do. Thanks again.
Mine has both a filler cap and grommet.
"Negative people always seem to have a problem for every solution" |
