Old 03-04-2007, 11:59 PM   #1
BCOWANWHEELS
anybody runnin the 19.5 rims on there 1 ron
i was wondering if the 1 ton dual rear wheel 1971 & 72 model trucks could fit the 19.5 modern rims. anybody runnin em ?
bob
BCOWANWHEELS is offline   Reply With Quote
Old 03-05-2007, 12:21 AM   #2
kwmech
Re: anybody runnin the 19.5 rims on there 1 ron
Had a 1 ton about 6 years ago that came from the factory with 19.5s and a GVW of 14k
Old 03-05-2007, 12:28 AM   #3
They used 19.5s back then.The tires were always tougher to find,even into the`92-up 3500HDs.But,now they are used on alot and are prolly more available.
Old 03-05-2007, 11:05 PM   #4
BCOWANWHEELS
WELL alcoa and accuride dont make aluminum 19.5 wheels anymore for our trucks. they do make 16" alum. rims however. but they are 295.00 each. looks like i,ll be runnin 19.5 steel rims. i,ve got a good source for them and it will help out my gear ratio when the 6 bt engine goes in. glad to hear they will fit.
thanks guys
bob
Old 03-06-2007, 12:15 AM   #5
lutherb69
They also sale 22.5 wheels too.
lutherb69 is offline   Reply With Quote
Old 03-06-2007, 12:44 AM   #6
BCOWANWHEELS
the 22.5 rims are 10 lug wheels. they dont make them for the 8 lug x 6.5 bolt circle and also the center hub pilot hole is alot bigger also. so 22.5 is a no go for out trucks with the stock front end components. c30 drw i,ve been on the phone with the alcoa wheel tech guy today for over 1 hour also the accuride wheel guy. no longer available for each of them.
Old 03-06-2007, 01:34 AM   #7
lutherb69
Oh saw that they sale adapters from 8 to 10 lug on their web site.
Old 03-06-2007, 02:09 AM   #8
chc
I havent formally introduced myself.But I check this site everyday. I have a 72 c30 dually. I spoke to a guy in Brea, Ca. today who says he has 19.5 rims that should fit my 72. he needed to know the eaxact measurement. I got busy at work and couldnt call him back. He says he bought a container of them straight from the manufacturer.I think he is asking 12 or 13 hundred for 4 wheels. They have 8 holes. He has three different sizes. Will I get in trouble if I put his number up? I love this board and I definitely dont want to do something bad.
chc is offline   Reply With Quote
Old 03-06-2007, 02:59 AM   #9
GREASEMONKEY72
GREASEMONKEY72's Avatar
if youre talking about useing the single wide wheel instead of the 2 wheels on the dually i heard that when you put them on that the handling sucks and it hurts the ride quality to and that you are better off keeping the dual wheels
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 03-06-2007, 03:04 AM   #10
chc
Actually you use a steel wheel on the inside rim in the rear. I have seen other setups like that. Mainly to save money on the extra 2 rims you wont see on the outside.
Old 03-06-2007, 03:57 AM   #11
bad_turbo
turbo enthusiast
bad_turbo's Avatar
my '69 flatbed dually came with 18's. I drove it for a year with those on it with no problems. Took them off to put 16's on since nobody had the tires for the 18's, and nobody wanted to mess with the split rims. Rides better with the 16's, but looked better with the 18's.
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 03-06-2007, 10:11 AM   #12
They make simulators for the 19.5s.
Old 03-07-2007, 02:57 AM   #13
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
bob
Can you pm me some info on where to get them ?
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 03-07-2007, 03:20 AM   #14
1969 GMC
1969 GMC's Avatar
I believe that every P30 van I've ever seen has 19.5 rims. I could be wrong, tho.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 03-07-2007, 08:12 AM   #15
A zillion UPS trucks...I like the old 8-holers used into the 60s.
Old 03-07-2007, 08:43 AM   #16
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Yes, P series vans had 19.5's
Also, Rickson Wheel makes 19.5's in several different styles including aluminum.
