03-05-2007, 01:52 AM | #1 |
Changing Steering Columns
How hard is it for the swap? what must be done to do this??
thanks in advance |
03-05-2007, 01:51 PM | #2 |
Re: Changing Steering Columns
03-05-2007, 01:54 PM | #3 |
It's pretty straight forward, just looking at that needs to be done. I did mine, having never dont it before and it took me about 3 hrs, not bad for first time.
Happiness is towing your "new" truck home. 1972 C-10 1982 GMC (parts truck??) 1969 c10 parts truck 1969 C-10 ( my sons) 1992 Silverado 4X4 (now the boys truck)(now mine again) 2002 Tarus (my wife loves that car) |
03-05-2007, 02:03 PM | #4 |
depends on what you are swaping into your truck, electrical hooksups might be different, length might be different, shifter linkage might be different, mounting plate might be different,
I know that it's easy to pull one out, I have to rebuild my tilt before installation though. Lots af variables to look at but it's not impossible. Lay them beside each other and compare....
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
03-05-2007, 05:39 PM | #5 |
Im putting in a new polished column from flaming river...
03-05-2007, 06:52 PM | #6 |
Corkscrew - we need more input before we can give feedback. A picture of the column going in would help. As msgross points out lots of variables. Are you going to use the original mounting gasket and ring? Will the neutral safety/reverse switch fit and how about the wires? Is the turn signal wiring and terminal compatible with the cab wiring? What about tranmission linkage?
As to time - it takes me about 15 minutes to pull a column. Conversion may take another 20 minutes. I also like to change the steering wheel - about 5 minutes with a wheel puller. Installation and adjustment may take 30 minutes. So anywhere from an hour to all day.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
03-05-2007, 09:50 PM | #7 |
what are the steps needed to remove the column??? like what do i take off at what time and such...
03-05-2007, 10:24 PM | #8 |
I disconnected my rag joint, firwall brackets, under dash brackets and pulled the whole thing (floor shift). I'm still at that point.....
