Son of a gun
What year ball joints are the same?
Are ball joints (upper and lower) for 73-87 1/2 ton trucks the same as a 72?
and/or are ball joints (upper and lower) the same from 63-72 I guess the real question here is what year ball joints (upper and lower) will interchange with my 72 spindles on my 69 truck? I know that I can go to the parts store and get them, but I have some NOS parts and I would like to use what I have if it will cross reference. THANKS!!! Bill Last edited by Bus Ted Knuckle; 03-05-2007 at 10:56 AM. |
Re: What year ball joints are the same?
The differences in the ball joints is in the taper for the spindle they will all mount to the A arms. In your case you would need 71 up joints to fit the taper of 72 spindles.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
71-72 is about it. The 73+ are different.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
