Old 03-05-2007, 12:37 PM   #1
68jimmy
68jimmy's Avatar
Ignition switch replacement
Well after 39 years my ignition switch has finally had enough. When I start it it if I just move the key slightly or leave the keys in it cuts out. I'm assuming that the switch internally has an issue.
When I order the parts to do this what all should I get besides the actual switch itself? Bezel, spacer, etc...
TIA!
78 C10 LWB Super Cheyenne
68jimmy is offline   Reply With Quote
Old 03-05-2007, 01:40 PM   #2
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: Ignition switch replacement
TIA!
when i replaced mine i only change out the switch
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 03-05-2007, 02:10 PM   #3
68jimmy
68jimmy's Avatar
Well after talking to the helpful staff at gmc pauls i decided to purchase a new door/ignition lock cylinder kit as well. Figured the old cylinder was pretty worn as well.
