How many quarts of ATF in a TH350?
Hi guys,
I just drainded my trans and changed the filter. Put the new gasket on the pan and bolted it all back together...went to my chiltons to see how many quarts of ATF to put in and........it doesn't say! How many should I add before I start the motor and check the fluid???? |
Re: How many quarts of ATF in a TH350?
Man, put about 8 in it and check it!!. I know the converter holds 1.5 usually and it took me about 10 to get one full I installed.
Slots go on anything!
If all you did is pull the pan and changed the filter, you will need 5 quarts. If the whole thing was drained, including the converter, it will hold 11. That would be in a case such as a rebuild, etc.
Chevys Kick A$$
^Yeah what jonboy said! If you only drained it and replaced filter.
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
