Old 03-05-2007, 01:26 PM   #1
dkooi
dkooi's Avatar
E-Brake Cable
I was wondering if any of you had pics of how the e-brake cable that runs through the firewall hooks up to the pedal/release mechanism inside the cab. I am specificaly interested in how the cable is held in place on that mechanism. Everytime I push on my e-brake pedal, it just pulls the cable into the cab without putting pressure on brakes. THis is on a 72 Chevy
dkooi is offline   Reply With Quote
Old 03-05-2007, 01:42 PM   #2
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Re: E-Brake Cable
I would check under the truck first. I have found that many PO's have disconnected the center pull piece or one side is disconnected or damaged causing the problem. The clevis inside the cab, connected to the brake mechanism is very robust and seldom fails.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 03-05-2007, 01:52 PM   #3
bobthecop
bobthecop's Avatar
Re: E-Brake Cable
Happiness is towing your "new" truck home.
1972 C-10
1982 GMC (parts truck??)
1969 c10 parts truck
1969 C-10 ( my sons)
1992 Silverado 4X4 (now the boys truck)(now mine again)
2002 Tarus (my wife loves that car)
bobthecop is offline   Reply With Quote
Old 03-05-2007, 02:05 PM   #4
msgross
msgross's Avatar
Re: E-Brake Cable
It should pass through the frame under your feet (fixed there) and connect to the large cable going to the back. Check out LMCtruck to some pics...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 03-05-2007, 02:14 PM   #5
dkooi
dkooi's Avatar
Re: E-Brake Cable
Well I'm pretty sure that I have all the pieces, however I have been wrong in the past. But maybe I can elaborate a little on my problem. The primary e-brake cable consists of two main parts, the outer sheath and the internal cable that actually pulls on the equalizer and intermediate cable. What is it that holds sheath in place while the internal cable is pulled to apply the pressure? There were a couple line clamps, one on the frame and one on the inner fender panel, but they were never tight enough to keep the sheath in place while pressure was put on the pedal. I don't know, maybe the e-brake is overrated!
Old 03-05-2007, 03:18 PM   #6
Rollie396
someday it will be done!
Rollie396's Avatar
Re: E-Brake Cable
Well I went through my pics to see if I had a decent one which I don't.The following is the best I could find but they ain't great.
I can't recall everything about the ebrake system,but do you have that clamp on the pedal assembly in place (the one with the shiny clean bolt head)?I'm thinking that that is the one that holds the outer sheath stationary.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 03-05-2007, 03:28 PM   #7
dkooi
dkooi's Avatar
Re: E-Brake Cable
Thanks Rollie396, that's what I've been looking for. I have the line clamp for the pedal assembly but it wasn't tight on the sheath part of the cable. I guess that clamp goes right over the end of the cable where it's diameter is a litte larger. Thanks a bunch for the insight!
Old 03-05-2007, 03:32 PM   #8
Rollie396
Rollie396's Avatar
Re: E-Brake Cable
glad it helped you.
'80 LWB 2wd beater
my pics
