![]() Join Date: Feb 2004
this rear ends got me boiling :-(
well i bought moser axles for my 67 and while i was at it had them convert the bolt pattern to 5 on 4 3/4 so im going to change them out and the bearings and seals while im at it so i open it up. i go to take out the pin retaining bolt and guess what it twist off with ease so now i have the small pin portion stuck in the large pin that goes between the axles, so i drill a hole in it and attempt to remove it with an easy out, guess what the easy out broke off in it, so now i try to drill it again and am burning up bits left and right, guess im screwed and will have to find another rear end to rebuild .....
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
Too many projects!!!
Re: this rear ends got me boiling :-(
Hmmm..that's not an easy one..I just took a rear end apart the other night..but luckily everything came apart as it should.
I don't know of any way to get that apart without really screwing up the carrier ......unless...Could you drill out the end of the big pin? that would drill through the small pin holding it in place...but it still wouldn't solve the problem of the smaller pin being broken off in the carrier... At the very least, I'd say cut the chunk open (to get the axels out) and find a new chunk....or a new rear end.
Sean ![]() 1995 Buick Roadmaster Sedan 2004 Chevy Trailblazer 5.3L V8 1963 Chevy Biscayne 4D Sedan 1971 Chevy C10 (now have 70 cab & frame) 1968 Chevy C10 (parts for the 70) 1991 Oldsmobile Custom Cruiser (Chevy 355 motor) 1937 Pontiac 8 4D Touring Sedan (in pieces) Jacksonville, Florida |
well looks like im going to have to torch it out. if any one need to make a little money let me know im gona need a hole chunk pin and all.
The LuvShack Garage
Sorry for your loss, this happened to me, It is still laying in the floor at my MIL's house
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
Ouch. I feel your pain.
Since you aren't saving the axles, l'd take a torch to the C-clips that hold the axles in. Once they're gone, pull the axles. Once they're out, then you can pull the carrier. Toss it in the heap along with the axles. Maybe you can save the gears if they're a desireable ratio for you. Non-posi carriers should be fairly inexpensive ($100 or less), just be sure they're the right series as yours. Posi carriers (Eaton) run about $400 new. Good luck.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe Last edited by mnunn454; 03-05-2007 at 08:20 PM. |
I Don't Know How Much Room You Have To Do This, But I Have Got Broken Off Bolts Out By Using Penatrating Oil, A Chisel, And A Hammer. Spray It Up Well, Chisel Into The Top Edge Of The Broken Off Bolt, Then Start Chiseling Counter Clockwise To Turn The Bolt. Or I Have Welded A New Smaller Bolt Onto The Broken Off One, Then Heat Up The Outside Of The Hole With A Torch, Then Turn The Welded On Bolt Carefully. Both Work Well If You Have The Room. Just A Thought. The Worst That Could Happen Is You're Back To Where You Are Now. Good Luck To You!!
![]() - 1972 350 ENGINE - MUNCIE SM 420 - 4.56 GEARS |
WAIT!!!
Put the torch, hammer and dynamite away!! Take it to a shop that has a EDM machine. It will remove the bolt and tap cleanly and completely... A hammer really isnt a tool that should ever be used outside of bodywork and bearings by daddy always told me... a good shop that I have used somewhat nearby is Reliable EDM, Inc. 6940 Fulton St. · Houston, TX 77022 800-WireEDM (800-947-3336) It wont take them but 20 min to blast it out when its set up. Good luck! Will
1970 C10, shortened long bed, Alum Headed full roller 383 (with Victor, 750DP, stainless rockers, behive springs, CNC ported heads) TCI SSF 700R4, 4.10 Posi, Bagged on C-Notch and 2.5 spindles. Air Cond, black out tint, satin black paint, custom interior, rolling low and not so slow... |
#8 | |
![]() Join Date: Dec 2006
Yes Yes Yes. this is the exact tool you need to fix this. The best part is it's not expensive. I have worked in a machine shop and had horrible experiences turn good with this thing. It actually reverse welds the bad stuff out and does not hurt threads or pin holes or anything. Very good advice there. |
well never herd of an edm, i can tell you this im pretty shure i have alread damaged the threads, you see when you drill it unless you have a relly long bit you kinda have to go at an angle that may be why i broke off the tap, and you cant pull the thing out to get straight on it cause its locked in, any ways i figure ill torch it out later, an old buddy of mine hunted me up a complete 68 rear yesterday for 150.00 and its laying in the floor now i guess it will be good to go through it in the floor at least easier than under the truck, im praying the same thing don't happen though, bad part is i don't know what gear the new one is, my old one is 3.73 witch is optmal for my motor set up.. hopfull better luck next time
ok then, easy....
take your new one to the EDM, and have THEM remove it... Bad mongo, no torch, hammer and drill for you! ![]()
You should be able to get the old carrier apart and out without damanging the gears..the install those gears into the other rear end.
