Old 03-05-2007, 08:09 PM   #1
71jimmy
71jimmy's Avatar
Rear Spring Schackle bushing
I'm putting a lift on my Jimmy, I've got the rear apart. The original rear spring shackel bushings are toast. NAPA can't get them. I called a special spring manufacturer in town, he says he's got the bushings but they will be crushed when pressed into the shackle, he recommends buying new which he charges $45 per side. I see LMC carries them, for much less by the way. Just wondering what others have done? What other alternatives do I have? And were else can I buy them?
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 03-05-2007, 09:59 PM   #2
tbreaden
Re: Rear Spring Schackle bushing
You can get polyurethane bushings that do not have to be pressed in. but you have to cut or burn out the old ones.
tbreaden is offline   Reply With Quote
Old 03-06-2007, 01:15 PM   #3
OLDCHEV4X4
OLDCHEV4X4's Avatar
I bought the whole shackle with the bushing in it from the dealership. They dont look like the original ones but are the right size. And very afordable too.
They are from the 73 and up trucks.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 03-06-2007, 02:49 PM   #4
71jimmy
71jimmy's Avatar
Thanks for the repsonses tbreaden and OLDCHEV4X4. I've now looked at the ORD greasable bushings for the shackle and springs. It would be a little more work, removing the old etc., and a little more money. Not to mention having to remove the bushings from my NEW springs, YIKES. But they claim it improves ride quality and articulation.
Anybody using these? Can you confirm the claims? Is it worth it?
I won't be using my rig for hardcore offroad, but I would like the best ride quality I can get, knowing that just lifting the suspension will make it ride stiffer. I'm using the six inch lift Tuff Country easy ride springs.
Old 03-06-2007, 10:48 PM   #5
msgross
msgross's Avatar
Do you have a website for those bushings? I had to burn my shackles off anyway so I am searching for options too.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 03-06-2007, 11:29 PM   #6
71jimmy
71jimmy's Avatar
Here ya go!
http://www.offroaddesign.com/catalog/greasebushings.htm
Taking the shackles off was extremley difficult. Ended up using a sawsall on one end of the bolt and ground down the other end before I got them out. Spent several hrs on just that, what a pain.
Old 03-07-2007, 07:31 AM   #7
msgross
msgross's Avatar
thanks... I need to find front ones now..
The Garage:
Old 03-07-2007, 09:47 AM   #8
OLDCHEV4X4
OLDCHEV4X4's Avatar
for the front ones I used 2" x 1/4tk steel , cut them to length, drilled the holes, and welded a brace in the middle. And you wouldn't have to have the brace. I just wanted one.
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 03-11-2007, 06:08 PM   #9
jacobs
jacobs's Avatar
Years ago, I knew someone who made (he had a lathe) teflon bushings. He claimed they were really great.
jacobs is offline   Reply With Quote
