Old 03-05-2007, 10:13 PM   #1
Jaredm82
Active Member
Jaredm82's Avatar
Check out my progress...
I painted from the notch back because that part is done now. I bent some straps and welded in a cross bar for my fuel cell. I mounted both my tanks and put the compressor under the cab. I tefloned all my fittings and got them in place. All I got left to do as far as plumbing goes is run the lines and wire the valves. After I find a color to paint the inside of my truck I can start putting the front end back together... And I also included a picture of my new wheel/tire combo! I sold the 20"S and picked up some wheels and had them powdercoated. Then I found some brand new skiny whites for 140 and some brand new hubcaps for 80. I think the set up looks *****in!!! I've got a brand new complete chrome molding set and Im going to eventually go with the factory 2 tone turquoise and ivory. What do you guys think?
Jaredm82 is offline   Reply With Quote
Old 03-05-2007, 10:16 PM   #2
Jaredm82
Active Member
Jaredm82's Avatar
Re: Check out my progress...
Oh ya I forgot to say that in front of the notch is not finished... I still have to remove the links and rearend so I can clean them up and paint them. THen I have to weld in some gussets on the bag brackets as well and brackets to the front link mount. Lastly I have to bend/cut/make room for my driveshaft to clear the back of the cab...
Old 03-05-2007, 10:20 PM   #3
63sbssbbw
UCA63
63sbssbbw's Avatar
looks awesome!!
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 03-05-2007, 11:43 PM   #4
jimmydean
jimmydean's Avatar
looks great! That's about the same size tire I got for my rig.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
