Old 03-05-2007, 10:39 PM   #1
67arch
WTB:Patience and Talent
67arch's Avatar
Airbag fitting help please
Ok so I may be just wacko or something I have firestone 3/8 port bags. I bought 3/8 valves , tee, cross, and ptc male adapters from ***************** Everything fit together except the male ptc adapters didn't fit in the bags, it is too big. Measures almost 5/8 in thread size and bag exactly 3/8. Anyway what do I need?
69 shortwide
67arch is offline   Reply With Quote
Old 03-05-2007, 11:24 PM   #2
Rollie396
someday it will be done!
Rollie396's Avatar
Re: Airbag fitting help please
Sounds like they sent you the wrong fittings?What does your invoice from SD say they sent you?If you're in a hurry you could run down to your local tractor trailer supply store with one your bags and get the right fittings (that's where I got all of mine).
Or,if there is enough room use the fittings you have with a male female pipe-pipe reducer.Though that's just another place for a leak to occur.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 03-05-2007, 11:42 PM   #3
jimmydean
jimmydean's Avatar
3/8th is 3/8. I didn't know SD even had 5/8th fittings, but I'm sure it's possible. Most of the air ride stuff I've seen is either 3/8 or 1/2. Call them up, they should make it right.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 03-05-2007, 11:44 PM   #4
scoot
scoot's Avatar
i don't think your bags are 3/8 port. with that measurement it is more likely 1/4 port. basically you need to get a 1/4 npt to 3/8 tube fitting.
scoot is offline   Reply With Quote
Old 03-06-2007, 01:22 AM   #5
Jaredm82
Active Member
Jaredm82's Avatar
Im with scoot on this one.
Jaredm82 is offline   Reply With Quote
Old 03-06-2007, 02:51 AM   #6
FLEET72
FLEET72's Avatar
Or you could just re-tap the bags to 3/8" and use the fittings you already have.
Oscar
'72 Shortbed Fleetside
'95 Jimmy 4X4
'69 GMC Custom Camper
FLEET72 is offline   Reply With Quote
Old 03-06-2007, 12:40 PM   #7
SlammedDime
SlammedDime's Avatar
The width of the threads does NOT equate to the size of the threads. A 1/4" NPT port will have a diameter of about 3/8". A 3/8" port will have about a 1/2" diameter, and so on and so forth.
I wouldn't tap the bags, I'd just get new fittings. Takes less time and unless you have the right drill bit and tap size, will cost you less money.
Matt
Admin @ AirRideTalk.com
Win FREE Viair compressors!
SlammedDime is offline   Reply With Quote
Old 03-06-2007, 01:19 PM   #8
Shane
Shane's Avatar
Slammed Dime is correct. NPT fittings are sized according to the particular PIPE SIZE they were designed to be used with ... NOT the thread size. Sounds like the ports on your bag are smaller than 3/8".
For example:
1/8"-27 NPT MALE END is going to measure approx. .363 at the first thread (small end of taper)
1/4"-18 NPT MALE END is going to measure approx. .477 at the first thread
3/8"-18 NPT MALE END is going to measure approx. .612 at the first thread
1/2"-14 NPT MALE END is going to measure approx. .758 at the first thread
Hope this helps.
Shane is offline   Reply With Quote
Old 03-06-2007, 06:35 PM   #9
67arch
67arch's Avatar
Thanks alot guys. Starting to make sense now. Guess I need two 1/4npt x 3/8ptc fittings. I actually under ordered fittings by 2 so I'm golden.
69 shortwide
