Old 03-06-2007, 01:29 PM   #1
jdhcth
jdhcth's Avatar
Makin' too many volts?????
What could be causing me to make too many volts? At ilde I'm fine, around 12 volts, but at speed it pegs the volt meter out. The voltage regulator is just a few months old and my "GENERATOR" light does not come on like it did when the old reg had gone out before.
Its too many volts for the radio too, it will only come on when the RPMs go back down and the volt meter reads 12v.
HELP!!!!
JD
jdhcth is offline   Reply With Quote
Old 03-06-2007, 01:34 PM   #2
bobthecop
bobthecop's Avatar
Re: Makin' too many volts?????
It should run around 14 volts any more and the regulator is not working
Happiness is towing your "new" truck home.
1972 C-10
1982 GMC (parts truck??)
1969 c10 parts truck
1969 C-10 ( my sons)
1992 Silverado 4X4 (now the boys truck)(now mine again)
2002 Tarus (my wife loves that car)
bobthecop is offline   Reply With Quote
Old 03-06-2007, 01:46 PM   #3
jdhcth
jdhcth's Avatar
Yea, but what's makin' my regs go out so often? The Alternator is new, well a new rebuilt, and this regulator was a high-dollar Borg Warner, previous one was a cheapy.
Maybe I'm overlaoding the 60Amp alternator? All I've added was the stereo and it ran great for 2-3 months. Before that I didn't even have a stereo and it still seemed to kill regulators.
JD
Old 03-06-2007, 01:51 PM   #4
67ChevyRedneck
67ChevyRedneck's Avatar
My truck would overcharge and undercharge randomly. It would jump to 18V while running, and then fall to 10V. It was retarded. After cleaning wires, having the alternator checked, and swapping out 3 voltage regulators I finally converted to an internally regulated alt. out of a mid 80's silverado. I think they at 90 amp alts. No more voltage regulator.
Click the linky to see more
http://67-72chevytrucks.com/vboard/s...d.php?t=230011
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 03-06-2007, 04:31 PM   #5
Fred T
Cantankerous Geezer
Fred T's Avatar
Are your alternator and regulator the same amp rating?
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 03-06-2007, 04:45 PM   #6
724x4a/cchevy
Self-proclaimed LED man
724x4a/cchevy's Avatar
im kinda in the same boat as you. "Project Bluebird" jumps really hard continuously from 12 to 14 volts. Makes the lights flicker when at idle.
My LED Website
My Photobucket Album of LED's
Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK
I also do LED:
-Third Brake/Cargo
-Brake (truck and burb)
-Reverse (truck and burb)
-67-68 Front Turn Signals
-69-70 Front Turn Signals
-71-72 Front Turn Signals
-GMC Front Turn Signals
I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once
Norwood Survivor
724x4a/cchevy is offline   Reply With Quote
Old 03-06-2007, 04:46 PM   #7
As2rd
As2rd's Avatar
I am also suffering from this problem. The volt gauge is reading 13.5 when the engine is running and 13v when its off. My 5amp fuse keeps on blowing out when i hook up the memory wire to the battery . Any suggestions?---Andy
1972 Chevy Truck
350ci/th350 Auto.
Daily Driver
As2rd is offline   Reply With Quote
Old 03-06-2007, 04:54 PM   #8
76bonanza
76bonanza's Avatar
As stated before you should have around 14.5 volts with the alt running. that is normal any more than 14.5 and you have problems.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 03-06-2007, 07:36 PM   #9
As2rd
As2rd's Avatar
does anyone else know why my radio's memory fuse keeps blowing out? Its a custom autosound and i just got it back from tech support which they replaced a crystallized wire. Im thinking about adding a 2ohm resistor but that will take away voltage, Will it still be ok to do? or is there another way? ---Andy (sorry bout the thread jack )
1972 Chevy Truck
350ci/th350 Auto.
Daily Driver
Old 03-06-2007, 07:45 PM   #10
jdhcth
jdhcth's Avatar
OK. I got home and unplugged the Reg and plug an old one in, that DOES make my Generator light come on because it doesn't make enough voltage. I stayed around 12-13 volts like it's supposed to regardless of the RPMs. So the problem IS my new, expensive voltage regulator. Plugged it back in knowing I need a new one tomorrow.
Well, as electrical system go, as I plugged it back in I have normal voltage. Like nothing was ever wrong.
Maybe it needed to reset itself, who knows?
On the subject of a new style one wire 90-100 AMP Alternator, what make them so special? I mean it still has a voltage regulator, just internal. These don't go out as often????WHY?
Thanks all,
JD
Old 03-06-2007, 08:21 PM   #11
msgross
msgross's Avatar
one was designed in the 60's and the other in the 80's maybe? i'm switching as well...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 03-06-2007, 08:51 PM   #12
84_4x4
84_4x4's Avatar
HELP!!!!
JD
you have to good of a ground lol rust your ground wire and should charge normally
1971 c10 350ci long bed fleet side
84_4x4 is offline   Reply With Quote
Old 03-06-2007, 09:23 PM   #13
tracterman2
tracterman2's Avatar
just get rid of all of it and put on a one wire internally regulated alternator...you can pick them up for around 95 bucks or less and I think they are between 80 and 100 amps, so they'll take most anything...you may also check all your wiring under hood and dash...a short that only shorts from time to time will cause a load unload problem with regulators
I'm Your Huckleberry.
You Ain't No Daisy.
tracterman2 is offline   Reply With Quote
