Manual valves
I'm going to put bags at all four corners. I want to keep it simple as possible. I might not even use a tank. But I still want to be able to control the rear from inside the cab.
The rear will be adjustable to handle loads. And also be independent side to side to counter roll. The front will be static. I see two types of manual valves from MIC. One is a 2-port valve, that I'm guessing is either open or closed. The other manual valve is a 3-port 2 position valve. But I don't know what the 2 positions are. Anyone know? I called and and got a busy signal. The picture shows the toggle in the middle, i wonder if it's actually a 3 postion valve.
'67 C10 Short Stepside 5.0TPI/700R4 Last edited by CochinoFilipino; 03-06-2007 at 03:32 PM. |
Re: Manual valves
This is the type of valve I was looking for, 3 way 3 position. Two of these and I should be good.
http://www.coolcars.org/air/Detailed/40-SW33.htm
'67 C10 Short Stepside 5.0TPI/700R4 |
Re: Manual valves
I've used the MIC valves in the past with good results. I don't remember the part# but the least expensive one (it has a cylindrical look) works great, and should be exactly what you want. The other one (that looks like a billet block with MIC machined into it) works well also... just a little fancier and a larger orfice.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
#4 | |
Re: Manual valves
![]() Join Date: Feb 2006
Re: Manual valves
i used them on a car about 5 years ago.. never had any issues
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!! |
#6 | |
Re: Manual valves
http://www.masterimagecustoms.com/store/manualav.html I'm looking to use just one (3 port 3 position) valve for each bag (up,down,closed) I sent an email but haven't got a reply yet. Thanks,
'67 C10 Short Stepside 5.0TPI/700R4 Last edited by CochinoFilipino; 03-07-2007 at 01:42 AM. |
#7 | |
Re: Manual valves
Re: Manual valves
Cool, Thanks
