Old 03-06-2007, 04:38 PM   #1
Mt Man Chad
Mt Man Chad's Avatar
Question Cab & Core Support Mounts?
I'm looking to order mounts for my cab and core support this week.
Has anybody had experience or any input on using Rubber vs Polyurethane mounts?
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 03-06-2007, 04:48 PM   #2
AH619
AH619's Avatar
Re: Cab & Core Support Mounts?
I Installed The Poly And It Made My Swb 4x4 A Lot Rougher Riding.every Bump Seemed To Compress My Spine.very Noticable.
72 2wd lwb cheyenne super youngest son.green/white
72 2wd lwb cheyenne super oldest son.green/white
71 4wd 3/4 cheyenne super frame off manderin
copper / white 4 inch lift. FINALLY DONE / SOLD
72 4WD SWB CHEYENNE BLUE/WHITE 388 AUTO
REMEMBER THE COPS NEVER THINK ITS AS FUNNY AS YOU DO. NORWOOD SURVIVOR
COPPERTONE BUILD THREAD/ http://www.67-72chevytrucks.com/vboa...d.php?t=259856
AH619 is offline   Reply With Quote
Old 03-06-2007, 06:48 PM   #3
cdowns
cdowns's Avatar
i have used the poly didnt like the vibration could hardly see anything in the mirrors 3months later threw them out and went original and was far better for a daily driver on the highway
Old 03-06-2007, 07:31 PM   #4
crazy longhorn
Fabricate till you "puke"
I did poly on my longhorn, & will say its a stiffer ride, but not bad. In my case , I needed the poly to get the clutch workin properly.....the old longhorn has a steel tilt clip, so basically 4 cab mounts is all I have to to handle the "squirm". IMO, the doors shut better, & even tho the ride is stiffer,the clutch lets up where its sposta......He!! i can live with that L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 03-06-2007, 09:20 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
As far as the rubber mounts, I have used new GM and new aftermarket ones. Save your money and buy aftermarket. Even at cost the GM mounts aren't worth the extra money. Aftermarket ones work fine.
