03-06-2007, 06:32 PM | #1 |
72 rear end
Got the motor done BB 407 with 460 HP and 450 tq with a TH400 with a 2600 TCI converter behind that. Now I need a rear end what do you guys suggest something strong. The truck is a 72 3/4 ton with a stock rear end going to need a locker and springs either leaf or coils any help greatly appreciated!!!
99 nbs 5.3L x-cab Hypertech programmer True dual 1 chamber flowmasters magnaflow x-pipe 3" PA body lift 315/75/16 BFG All Terrian 15.3 @ 89mph 72' C20 402ci sc,lb in bed tool box, and new paint http://www.cardomain.com/memberpage/456511/1 |
03-07-2007, 06:49 AM | #2 |
Re: 72 rear end
Which rear axle do you have? I have a small 14 bolt under my 70 3/4 ton. I would like to hear what other members have to say about upgrade options etc.
03-07-2007, 07:42 AM | #3 |
Re: 72 rear end
The HO52 Eaton can handle whatever you throw at it.Lockers are tough to find.You can use the 14-bolt application with 14-bolt axles,but the ends need a bit cut off and dressed.What suspension is in the truck now?I`d stay with that,unless you`re ready for some major work.
03-08-2007, 09:18 PM | #4 |
Re: 72 rear end
Also here is a pic of my rear end How much are we talikng in a 9" and I also hate buying parts 2...3...4... or more times!!! the truck is stock as far as suspension and rear end goes
03-09-2007, 07:02 PM | #5 |
Re: 72 rear end
Ttt
03-09-2007, 10:10 PM | #6 |
Re: 72 rear end
While a 9" adapted for your setup would be ideal, I'd think a normal posi 12-bolt setup should be plenty adequate for your output. If you have any doubts, add a "girdle" (I think they're called) to preload the rear caps and keep the ring gear in place under high torque loads, and maybe a set of billet axles.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe |
03-09-2007, 10:28 PM | #7 |
Re: 72 rear end
Gonna hafta try hard to damage that D60, the weak spot will be the 30 spline shafts over time.
03-09-2007, 10:52 PM | #8 |
its all about the +6 inches
Re: 72 rear end
just run what you have, no need to replace it
03-10-2007, 12:28 AM | #9 |
Re: 72 rear end
So it is a dana 60? how can I tell for sure?
