Old 03-06-2007, 07:12 PM   #1
84_4x4
84_4x4's Avatar
3 on the tree linkaging pictures
anyone have any pictures of their linkages i just got a set and now i need to hook them up and i cant seam to figure out which ones go where and over or under the clutch linkaging any pictures or advice would help a lot would like to have it working soon so i can get a handle on three on the tree before i drive to far
1971 c10 350ci long bed fleet side
84_4x4 is offline   Reply With Quote
Old 03-06-2007, 08:32 PM   #2
84_4x4
84_4x4's Avatar
Re: 3 on the tree linkaging pictures
pictures from the topside would really help im really confused on about how these linkages run or where to buy parts like the bushings
Old 03-07-2007, 03:04 AM   #3
crazyred
yeeha
crazyred's Avatar
ttt for you because I need to know too That would be one thing I never did get a picture of before it came apart
1969 GMC 910 97% rust free
2002 olds Alero
1986 New Yorker 4dr ... the new DD...My POS car... dude its got a turbo!!!
Don't drink and drive, you might spill something!!!
Daryl Kuchmak
crazyred is offline   Reply With Quote
Old 03-07-2007, 11:25 AM   #4
northerngmc
northerngmc's Avatar
There is a post in the FAQ sticky about adjusting the 3 speed manual. Maybe it will help.
http://67-72chevytrucks.com/vboard/s...d.php?t=215307
Or PM the author?
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 03-07-2007, 09:20 PM   #5
84_4x4
84_4x4's Avatar
yeah i already looked there no pictures of it i seam to be runnign into clearance issues with clutch linkaging
Old 03-07-2007, 09:53 PM   #6
CPNE
Resident Curmudgeon
CPNE's Avatar
Not sure if this helps, best I could do. This is a STOCK 69-72 small block/3speed column linkage set up. There ARE differences between 67/68 trannys and I6 setups (all years). It may also make a difference if you put your small block in the forward (factory correct) position, or in the rearward I6 position
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 03-07-2007, 11:36 PM   #7
84_4x4
84_4x4's Avatar
thanks that makes all the difference i was putting the rods in upside down no wonder they didn't want to line up thanks a lot now i think once i dint the pieces to connect them to the column and tranny i can get it to work
