Old 08-31-2002, 01:49 PM   #1
diehardrider
KEEP IT PINNED
oil filler
I recently purchased valve covers for my 454. They do not have hole in them for the oil filler and pcv valve.
I have the pcv taken care of already. All i need to do is decide on the location. MY PROBLEM IS FINDING SOMETHING THAT WILL WORK FOR THE OIL FILLER SIDE. Also were is the proper location for the pcv and oil filler as far as on the engine which side and position on the valve cover.
diehardrider is offline   Reply With Quote
Old 08-31-2002, 09:52 PM   #2
diehardrider
KEEP IT PINNED
no ideas? Am i the first person with the summit valve covers?
Old 09-01-2002, 02:35 AM   #3
hjalbert
cracker
hjalbert's Avatar
i may be dumb, and come off sounding mean, but you probalbly ordered the wrong ones, or maybe your intake used to have it but has been changed.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Harry John Albert III
located in Phoenix, AZ
1972 GMC JIMMY,
1969 lwb Chevy Frame,
1999 bmw k1200 ltc
1992 Kawasaki concours
1991 bmw k75
1973 cortez motorhome
hjalbert is offline   Reply With Quote
Old 09-01-2002, 10:15 PM   #4
diehardrider
KEEP IT PINNED
This is how they come. They give you instructions for the baffle for the pcv. It cost 25 bucks and i really dont want to buy another because the baffle will makeit hard to fill with oil.
Im wondering if i can just drill a hole and put a grommet in there.
RYAN KING
71 swb 4x4
Old 09-02-2002, 08:54 AM   #5
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
You'll need the baffle for the PCV or you'll be sucking oil into the carb. Many of people make that mistake and wonder why their engine is using so much oil!
As for the oil fill, I would think you could just drill a hole and use one of the push in rubber caps that were used on 72ish-up engines???
I agree in that these covers are made for an engine with a fill tube. I think you could add a fill tube but that would be the extreme I suppose.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
