Old 03-06-2007, 09:24 PM   #1
cfoust3
cfoust3's Avatar
Anyone else running a 327?
I was wondering what you have done to boost the hp? Mine is still stock, and I want to get some ideas how to juice it up a bit without breaking the bank.
Let me tell you what Melba Toast is packin' right here, all right. We got 4:11 Positrac outback, 750 double pumper, Edelbrock intake, bored over 30, 11 to 1 pop-up pistons, turbo-jet 390 horsepower. We're talkin' some ****in' muscle.
-Wooderson
From the movie Dazed and Confused
cfoust3 is offline   Reply With Quote
Old 03-06-2007, 09:30 PM   #2
gnarkill
gnarkill's Avatar
Re: Anyone else running a 327?
I got a 327ci punched .060 out so its a 336ci. All 327s come with Forged Cranks , I threw on KB pistons domed to hell, Eagle Rods, 64cc World Products S/R Torquer heads, HUGE Comp Cam Magnum Cam, Roller Rockers, 600cfm Holley carb, long tubes. The engine was balanced and I blueprinted it myself. I desktop dyno'd it at around 410hp around 6800.
PS Truck revs to the moon, i had it up to 7k before without it missing a beat, pulls hard as hell around 3800 to 6000.
gnarkill is offline   Reply With Quote
Old 03-06-2007, 09:35 PM   #3
skokie
skokie's Avatar
Did the 327s from 68 with a large journal come with a forged crank? How could you tell? I do have a 327 that is sitting on a engine stand begging for attention
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 03-06-2007, 09:35 PM   #4
cabinetguy
67 shorty
cabinetguy's Avatar
327's like to rev so get a cam and manifold that allow this.
67 SWB with enough parts to build two
cabinetguy is offline   Reply With Quote
Old 03-06-2007, 10:02 PM   #5
gnarkill
gnarkill's Avatar
Yeah man they all came with forged cranks, I got the large journal which is a 350 main size. The 1st ones came with small journals. I got a lot of work done to mine.
Old 03-06-2007, 10:03 PM   #6
Stroker
I'm not sure if they all did but my 68 327 3/4 ton had a forged large journal. Look at the parting line on the counter weights if the parting line is wide and flat it is forged. If it's a narrow peak then it's most likely cast. You can also tell by the way the crank sounds, if it rings when you tap on it it's most likely forged the cast cranks will have a lower pitched sound. Hope this helps.
72 SWB parts and pieces
Oklahoma
Stroker is offline   Reply With Quote
Old 03-06-2007, 10:16 PM   #7
cabinetguy
67 shorty
cabinetguy's Avatar
You can also tell by the color. Steely gray= steel, rusty brown= cast
Old 03-07-2007, 08:38 AM   #8
A 327 came in my`71 wrecker.I plan to rebuilt it all peppy-like for the`67 GMC I`m building.I`d like a Cummins in the wrecker
Old 03-07-2007, 02:37 PM   #9
speedracer
Blank
speedracer's Avatar
cam, roller tip rockers, intake, carb and headers, would be a good start without breaking the bank. after that maybe some heads and bottom end work. 327's rule!!
1969 lwb 4/6 drop 17x8-18x10 torque thrust II's 327-420hp 2004R 3.73 posi.
1977 Corvette 350-375hp 4speed, silver show car.
2002 S10 xtreme, work truck
2004.5 VW jetta GLI 1.8T 6speed, weekend warrior.
2013 Audi A3 TDI, the wife's car
speedracer is offline   Reply With Quote
Old 03-07-2007, 10:52 PM   #10
rust!!whatrust?
rust!!whatrust?'s Avatar
Never had a 327ci. Depends on how you plan to drive it but revy motors love gears.
Don't touch the Rust. Punk
rust!!whatrust? is offline   Reply With Quote
Old 03-07-2007, 11:52 PM   #11
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
speedracer has ya covered on the start.
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 03-08-2007, 12:12 AM   #12
chevymad
My 68 327 is a cast crank. So no they're not all forged.
70 C10 long fleet, 355/200 4r, 6 lug disc conversion, 3" drop
70 gmc changed to 67/8 chevy, 454 with voodoo cam, th400, all 74 running gear.. in progress
chevymad is offline   Reply With Quote
