Old 03-06-2007, 10:46 PM   #1
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Q-jet CFM
I went to the u pull it yard yesterday looking for a q-jet with an electric choke. I was amazed at how many are already gone!
Anyway, is there a way to determine the CFM on these or are they all the same? Is there a desirable car/truck to get one from?
Thanks,
Dean
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 03-06-2007, 11:21 PM   #2
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Re: Q-jet CFM
750 usually. There were some 850's but they are really rare. Do a Google search and you will find several good Rochester sites that will give you the specs. based upon the number stamped on the side of the carb. The electric chokes are the later models...late '70's-'80's.
They can all be modified for high performance. You got about the best they had to offer since it has an electric choke. Were there any more laying around there?
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 03-06-2007, 11:46 PM   #3
cooters
Re: Q-jet CFM
usually the u pull it yards pull them when they come in. Swap meets are the best place to find them.
cooters is offline   Reply With Quote
Old 03-07-2007, 07:36 AM   #4
neonlarry
neonlarry's Avatar
Re: Q-jet CFM
Look here:
http://dyeager535.topcities.com/qjetidentify.html
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 03-07-2007, 12:07 PM   #5
hyarbour
Re: Q-jet CFM
If you want the 850 G-jet look for an old Caddy or Olds Toranado, they usually have them. The monsters those cars had under the hood would need them
hyarbour is offline   Reply With Quote
