Old 03-06-2007, 11:16 PM   #1
WORNBRAKES
Power Brakes F/s (72)
Either complete or parts. You decide. From a 72 C20
Booster w/ master cyl and prop valve and brackets 45.00 SOLD
Calipers, lines, spindels, backing plate and rotors (could use turning), 100.00
Mario and Mandy
Hughesville, MD 20637
69 C10 305/350
71 K5 Basket case
75 K10 Rescue **Parting out**
77 MG Midget **Parting out**
15 6.7L Cummins
WORNBRAKES is offline   Reply With Quote
Old 03-10-2007, 12:07 AM   #2
WORNBRAKES
Re: Power Brakes F/s (72)
Ttt
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 03-10-2007, 12:04 PM   #3
GMCBubba
GMCBubba's Avatar
shipping estimate to 27713?
1969 GMC 3/4 ton, 307, 4-speed NP435GL, DANA 60, 4.10, HD rear leafs, manual everything, leaking oil and water. Now rocking 383, NV4500, power steering, power brakes. Finally undergoing restoration.
GMCBubba is offline   Reply With Quote
Old 03-10-2007, 02:20 PM   #4
Snew
What would also be needed to use those to convert my '69 C20 drums to disc? Can someone tell me if those would those work with my control arms and tie rod ends?
Snew is offline   Reply With Quote
Old 03-11-2007, 12:49 PM   #5
WORNBRAKES
GMCbubba, My scale broke. I am getting another one today and will get you a quote. Were you interested in all of it?
Snew, I looked at LMC's catalog and found different P/N for the upper and lower balljoints and outer tie rod for 71/72 3/4 Ton and the 67-70 3/4 Ton. I am not sure if the diamiters are a different size.
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 03-11-2007, 09:04 PM   #6
GMCBubba
GMCBubba's Avatar
yeah WORN, i'm interested in it all. it would be shelved for a later conversion, but the price seems to be about right to get it now. plus, there isn't too much 8-lug stuff that i've stumbled across...
Old 03-12-2007, 07:51 PM   #7
WORNBRAKES
Bubba,
I checked a few diff shiippers and this is what I come up with for the items listed below:
brake booster 35lbs 23x21x21
spindel/caliper/rotor 90lbs 18x18x14 X2
spindel/caliper 70lbs 18x18x14
booster, w/rotors, w/out rotors
DHL- 22.00, 44.00 X2, 33.00 X2,
Fed EX- 29.00, 50.00 X2, 33.00 X2,
GREYHOUND- 38.00, 70.00 X2, 60.00 X2,
Please let me know what you would like to do.
Thanks,
Mario
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 03-12-2007, 09:42 PM   #8
GMCBubba
GMCBubba's Avatar
mario, thanks for checking that out. with that almost doubling the price, i don't think i can make that commitment right now. plus, new baby coming in a week. still seems like a good deal for someone, though.
--michael
Old 03-18-2007, 12:56 PM   #9
WORNBRAKES
It is heavy but someone must need it?
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 03-18-2007, 04:25 PM   #10
Ole Blue 68
Ole Blue 68's Avatar
Let me know if your willing to split it up; I only need the m cylinder and prop valve. If so, price + shipping to 77345?
Ole Blue 68 is offline   Reply With Quote
Old 03-19-2007, 08:33 AM   #11
N2GMTrux
N2GMTrux's Avatar
If you will split the brake setup and Ole Blue takes the master and prop valve.
I will take the booster with pedal rod, and brackets. Shipping to Ft.Worth76133 or Will you be at the La Grave Swap Meet April 7th & 8th.
N2GMTrux is offline   Reply With Quote
Old 03-19-2007, 10:32 AM   #12
WORNBRAKES
I will split them.
Ol blue- 22.50+10.50 shipping =33.00 total
n2gmtrux- I will not be at the swap meet. I may not be in town.
For you, 22.50 + 11.50 = 34.00
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 03-19-2007, 01:50 PM   #13
Ole Blue 68
Originally Posted by WORNBRAKES View Post
I will split them.
PM Sent
Old 03-20-2007, 08:21 AM   #14
N2GMTrux
N2GMTrux's Avatar
I will buy them. PM sent
Old 03-20-2007, 10:49 AM   #15
WORNBRAKES
Booster and master cyl SOLD.
spindles, backing plates, calipers and rotors still available.
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 03-20-2007, 03:12 PM   #16
WORNBRAKES
Ole Blue- shipped USPS today
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 03-21-2007, 04:51 PM   #17
N2GMTrux
N2GMTrux's Avatar
M.O. sent by mail today at 3:50PM,,,,,,, Thanks
