Old 03-06-2007, 11:29 PM   #1
cstm68
cstm68's Avatar
air ride $$$$?
about how much woud it cost me to lower the back of my 68 swb with air ride? just for the parts.
how hard is it ?
cstm68 is offline   Reply With Quote
Old 03-06-2007, 11:49 PM   #2
st1x10
st1x10's Avatar
Re: air ride $$$$?
How low do you want to go? Is it coil rear?
Might check ***************** for prices.
1970 Chevy C10 "Under Construction"
2002 Chevy S10 V6
st1x10 is offline   Reply With Quote
Old 03-06-2007, 11:57 PM   #3
jimmydean
jimmydean's Avatar
Re: air ride $$$$?
It all depends on how low you want to go and how do you want to control it.
It's not hard, but if you want to do c notches, deluxe track bar, and shock relocators, then it's a little work. You have to decide what all you want.
You can run a tank, 4 valves, 1 compressor, 2 bags, hardware, fittings, hoses and gauges, track bar, shock relocators, an notches for about $600.
Or you could do hoses, bags, a couple fittings and shreader valves for about $200. But then you don't have gauges and you have to fill and dump your bags at the gas station. You also might hit the frame and your rear end might stick out one side.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
